WesMason
- Apr 15, 2008
- 107
Hello All,
I am in the final stretch of a restoration project on a '62 Starcraft with a 40hp Electric Sea Horse OB, Model RDS 23, s/n 2192397.
The engine hasn't run since 1992. It has compression (not sure how much yet), the carb aspirates, and the motor turns when I turn the key.
TO DATE:
Replaced both control cables
Pulled apart control box, cleaned, degreased, and re-lubed all moving parts
New Impeller, lubed lower unit.
BOUGHT carb kit (not installed yet)
Ok...first problem: Dropped lower unit, replaced impeller (old one was still very flexible, so saving as backup). I can't get the shift rod connector back together properly. If I losen the bottom nut/bolt too much for the shaft to slip in then I can't get the nut on the back to "grab" to tighten. If I tighten it enough to "grab" then I can't get the shaft into the connector.
Ideas? Thanks in advance!
Wes
TO DATE:
Wes
