1960 Glastron FireFlite has a new home!
Pmccraney
Re: 1960 Glastron FireFlite has a new home!
Did you pick up the "un-mentionable" yet? Just don't any of ur glasser friends over to help (we are liable to drink out of it, burp, crush it and ask for another...)*
*this statement is credited to smokeonthewater, the original author...
rrumba
Ensign
Rub a dub dub, 3 men in a tub..... Thanks rrumba, made it back. To an azz deep creek arising, about 4 days rain in 4hours:eek:
well at least you have a hull that should float should you need to get above the water...... now onto the good stuff..... git crakin.
glad you made it home safe and hopefully the water does not rise to much for you
jbcurt00
Strangely, work thought a work week should be before a boat pickup run, esp after a week off:facepalm:
I have half a mind (I know, I know. The MRS agrees) to get the mob riled up, give them the office address & tell them there's: Free brownies, free frosty adult beverages for all plus a free pristine condition 1942 Chris Craft twin cockpit runabout to the 1st to respond.
We're a 2 boat household and a Sat/Sun pickup is pending . 4hrs ea way.
Gotta stay off the forum & ebay late at night. Although I have used it well more then once, I still hate the "Or Best Offer" button on ebay...:rolleyes:
jbcurt00
Campus is 3 blocks away, lost 6 cars.... or at least they all floated down into a nice big pileup jumble at the far end of the lot. Oops, maybe campus should have closed the parking lot that's clearly labeled as IN THE FLOOD PLAIN:eek: Only had 3 people that " I thought I could make it, it didn't look too deep":facepalm:
Where was Bill Engvale? He could have handed out a great big ole stack of them signs....
Water overwhelmed my front porch drain, but only had @ 12" of damp carpet just beyond the threshold. Dang...... DeHu running & looks like it's drying pretty good....
vincechig1975
Sweet ride! Understand about the "Warden" but she's a good ole country gal so she's all for this project.;)
jbcurt00
Yeah, on the off chance there is something to that karma stuff, and being able to comfortably sleep w/ BOTH eyes CLOSED, it is now strictly the MRS or the ADMIRAL.:)
Thanks, I hope I do her justice & bring back all her former glory.
Thank you for stopping by our little shop of for a dose of crazy.
jbcurt00
Found a new online source for logos. Although it's not period correct, the upper one may find it's way on to the FireFlite or the trailer. The lower one matches the script on the boat. Both rear logo scripts are in ok shape and need to be reinstalled on the gold engine turned looking vinyl I can order online.
jbcurt00
Spent some time w/ a grinder in the FireFlite after work tonight. Forgot to talc up, it's been awhile, numb-skulled it:( Also removed about 80 screw cap snaps. Then moved on to removing a little of the rubrail!:D Only had 1 bind up & snap the bolt, and 1 that wouldn't break loose, and had to be cut. I'll need to replace a few of the bolts I removed, they were damaged during the uncovering stage
Unscrewed & removed starboard rear sections, about a large 1/4 of the total:
The last bolt on the far left of this rear area is where I had to cut a bolt.
Found a little bit of the original 'gold' vinyl that was behiind the Glastron script in the ellipse between the upper & lower rubrail sections at the stern:
I think this:
is an acceptable alternative, and will work with some of the Merc decals from the guy in NY. I still need to figure out how to best remove (reuse??) the flat clip thats pushed down & partially under glass to remove the Glastron script & a few of the other bits & pieces faux screwed to the hull.
The good new is that once I get the rubrail & a few other things out of the way, it's clear sailing to grind the hull/cap joint. There are very few SS screws holding the cap to the hull, and it will easily be lifted after grinding the interior seam covering glass.
It was good to get some time to work on her. Even if only for a bit. Had to make sure she knew I wouldn't ignore her...
Good luck getting over the hump tomorrow & towards the weekend!
Pmccraney
Glad to see you giving the Fireflite some love and attention.... Truly is one of my favorite classic glass boats on this site... Normally I'm not a fan of anything gold, but I think it will look awesome going back to the original on the name plate.
Keep plugging as time allows... Once you get that cap off, you will start moving fast...
Have a good one...
~rpm
jbcurt00
Thanks for stopping by, I think I'll like the machine turned vinyl better then the original check pattern.
Extra big thanks for not dragging our 'class'~dojo pix over & dropping it on my thread.:facepalm:
Much appreciated.
Once was quite enough, thank you very much:eek:
W/ all that extra real estate out at your boat yard, you ought to find that big open bow you were thinking of hacking the CC Lancer into!:rolleyes:
GT1000000
Pleased to see the FireFlite finally recieving at least a little attention, sheesh!...
I'll just bet everytime you walk by it, on your way to the tinny...its screaming at you..."Hey, I'm right here!, Look, see, your first, your one and only...wait where are you going...Noooo, not the metal one!?!?...:eek:...LOL
All kidding aside...I like the faux metallic Gold backing you are planning to use, even though it may not be 100% original, it looks like something they would have used...very neat!
What is it made of? Vinyl, Plastic, Decal...
Very excited to see the upcoming de-capitation...[that's my dark side talking]...
jbcurt00
Thanks for swinging by GT, it's always great to have you over.
It's automotive & marine vinyl from an evil-bay vendor: 2.5mils thick, 3-5 years UV life, longer when covered w/ Clear. Sold by the foot, in 25" widths. I need 5 feet. For $20, I may go ahead & get the silver engine turned as well. Last night, the FireFlite came to me in a dream & it had silver instead. But that's a ways off & I still need to get the rest of the goods that need more then a light buffing to get the chrome looking good again.
I need to shoot a pix of the back side of the gunnel for the Glastron script's attachment pegs. It's got those old style clips pushed down tight to the inside of the fiberglass. Then resin'd over. I got the glass & poly ground back but it's proving very difficult to get the clip away from the hull so I can back it off like a nut on a bolt...... It's why the Glaston badge in my Avatar no only has 1 peg in the back instead of 2. It snapped off while I was trying to get the clip loosened & slide up:facepalm:
I may have a pix showing it already, I'll need to go through my photobucket stuff
craigweaver
JBC, I just had cold shivers thinking of grinding again, lol
Glad she's getting at least a little attention these days. At least with having the tinny you can relax and take your time on the FireFlite!
jbcurt00
Yep, as long as I can stand the abuse the mob is throwing me over on the SC thread I started way too soon:facepalm:
I just have to remember that I have to work when I can, as much as I can, esp now that the commission rate has changed..... Better then unemployment...... And it's been a real slow winter anyway. W/ alot of folks depending on me finding them work too, it is very hard to take any of the time I've got accrued, sick or otherwise. So I plug along here & there, they'll both get done. Whether the SC club bashes me or not. I can take it, if they do....
jbcurt00
In light of the chanting going on over at my SC thread, I feel compelled to post here too:
Oh great 'glass goddess, watch over this humble vintage 'glass owner, please grant me the pleasure of a successful rehab, the fortitude to resist the forces of Tin that pursue & taunt me relentlessly. Give me strength to know when to ask for guidance, the will power to follow through on that advice, and the confidence to launch this beauty one day. But most of all, help keep my filters clear, my lungs healthy & my post glass boat encounter nights itch free!
Have a great weekend all, tin & glass alike. And you PVC/Plastic, sail & paddle guys too
craigweaver
JBC, sounds to me like you've gone a bit bi-polar, ya might wanna see a doc about that an get back to work on FF
bear_69cuda
So you got it.....
Yep....
I knew it.......
MBS...............
I flipping just noticed you have a second boat! And it's tin! WTH dude? Kiddin congratz it's awesome! I want one also....:eek:
jbcurt00
Stay tuned, there's something else a-brewing, I have learned the early trigger pull lesson. I shall speak of this no more until it can be completely revealed in totality. With recorded proof. But the wheels are a turning, just not the truck tow-rig wheels. Yet.
1973Chieftain
Now you are being secretive.... Did we all get to you that much over in SC waters? Or are the glass fibers getting to 'ya? :D
