1959 Glasspar G-3 Restoration
OCboat
I'm not brand new to boats but this will be the first restoration that I have attempted. I have owned a 1965 Seaswirl p-14 runabout for several years and I have made some cosmetic repairs including paint, but nothing like the work that this G-3 needs.
I Have split the deck from the hull and removed some of the floor and will start to remove the old transom this weekend. The transom on this boat is curved so I will need to install it in layers. I plan on using four 3/8" pieces of plywood for the new transom. The stringers are in decent shape and I will only need to remove and replace about the last foot of the 3 middle ones.
There is also several layers of old paint that I will need to remove before I can start to fill and repair all of cracks scratches in the deck and hull. I need to reinforce the supports under the deck in the bow. I also need to move the steering from the port side to the starboard side of the boat and fill in all of the holes in the dash.
Here is the boat from the first day that I towed it home:
And here are a couple of the stringers and transom:
Now the fun begins. I look forward to all the advice and encouragement along the way.
Woodonglass
Honorary Supreme Mariner
Re: 1959 Glasspar G-3 Restoration
Looking forward to following this one!!!
Willyclay
Just when I thought all the G-3's were gone, you found that gem. Good luck with that great old classic!
OCboat
Not much new to report. The weather has been rather cold and rainy so I'm in waiting mode. I'm stripping paint (many layers) from the deck but even the paint stripper does not do very well in these temps (low 50's). I can't wait for some warm weather.
bonz_d
I love the looks of those old Glaspars esp. the G-3. The one you found actually looks great for it's age!
Feel good knowing that Here in SE Wisconsin it's currently 9:40am and 12 degrees with a wind chill of ZERO! We're still makin ice, D'AMMIT
