Re: 1957 Evinrude Fastwin 18hp
Ok, so I said no problem, I will just take the prop off the '56 Johnson and put it on the Fastwin ... If it could just be that easy lol. It looks like the hub of the prop is not in the same position on the propeller and because of that, I can't screw down the prop nut far enough to get the cotter pin through the hole.
Again, here are some pictures to illustrate:
This is the prop that was originally on the motor:
This is the prop from the '56 Johnson:
Original prop:
Johnson prop:
