livinfulltilt
- May 1, 2012
- 73
Re: 1957 Evinrude 35hp
The beast lives!
*Ignition coils look new
*Spark checker showed spark on both plugs
*New champion J6Cs put in with .030 gap
*New fuel/oil mixed. Premium fuel used
*New lower unit oil
*H/S, L/S knobs set as per manual (seat, backed out 1 1/2 topside, seat, backed out 1 turn bottomside) I still need to do this under load though...
Ok, this is where Im going to start needing some advice....
I got her up and running at idle, no stalls, no jumps etc. The idle knob (top) was turned to seat, backed off 1 1/2 turns. At low idle I could seat the low speed (top knob) completely and it would not die out. The fuel pump was added to this motor, not sure if that will make a difference or not?
Next up, the LU was leaking oil as evidenced by the blobs floating in the "barrel". When the motor was NOT running there was water coming out of the "water exhaust port" on the LU. Any ideas as to what this may be? Im guessing bad seals?
I also found that the missing bolt was not sheared of in the shaft housing, so it looks as if *maybe* the threads could be re-tapped...I hope... Otherwise, would a helacoil be sufficient, or should I consider possibly tapping it out to accomodate a slightly larger bolt? Ideas?
The beast lives!
*New lower unit oil
