1957 evinrude 35hp problems running
kfa4303
Banned
Re: 1957 evinrude 35hp problems running
No problemo. We've all been there, that's why we're here. Happy tinkering.
HighTrim
Is that manually pulling it over?
HighTrim
I will, just trying to get it going. Just order the impeller today. Is there something miss up front of the carburetor? working on getting the manual. I am not sure about the compression relief.
you are missing the silencer fore of the carb
Parts manual here:
www.marineengine.com
Silencer, got it. I will order that also. The compression test was with the electric start. Also, How do I pull the flywheel?
nwcove
those compression numbers are on the weak side......you may want to get some other opinions on it before you start buying parts.
HighTrim
Agree, you are not going to run right with compression that low. Most of my Big Twins from '55 to '58 are in the 125psi to 145psi range.
Pull the head before buying anything and lets figure out what is going on.
BTW, that silencer is not something that you can order. Post a wanted ad at aomci.org in the webvertize or call a salvage yard listed in the FAQS
aerobat
Master Chief Petty Officer
from the european side of view on the one hand its an old piece of metal ready to be thrown away , on the other hand this engine is far older than me and what a fantastic piece of art !!! the compression shows this grandpa exhausted its life, its tired. so when interested in restoring it- rebuild it , if interested in just boating sell it for a few bucks to anybody and try something newer.
cheers !
nwcove
cheers !
with all do respect, old pieces of metal dont get thrown away ( especially old ob's) , old metal gets recycled. and that "old grandpa" may just need a shot of "whiskey" to free up his stiff joints! dont bury "grandpa" just yet, there could be another 50 years of good service there, with minimal $$.
glad im not a grandpa in europe!!! :eek: lol
aerobat
lets take a shot of canadian whiskey and let go boating ! i never saw an ob aloder than a 1977 mercury 50 hanging in pieces on a marina for museum . here in germany we ride EFi or direct injected outboards, so i,m just stunned what piece of grandpas you hang on the transom !
nwcove
good plan!!! we can take my 1957 5.5 and go trolling for broken down efi's and tow em back to the dock!!!! :p
HighTrim
:) I love towing in brand new $10 000 motors with my "grandpas"
I dont think Ive ever owned a motor as new as 1977, I do have a '76 55hp on my fishing boat if that counts.
kfa4303
Banned
Half the fun of using vintage motors is tracking down parts, learning new/old things, bringing them back to life with your own two hands and meeting new people who share the interest. It may not always be easier, but it's a lot more fun.
Warum so einfach wenn es so sch?n kompliziert geht?
Mas
The compression numbers are very low. This could be due to several things from easy to hard:
Testing procedures
The gauge used
Low battery voltage
Poor electrical connections
Weak starter
Head gasket leak
Stuck piston rings
Worn piston skirts
Worn/scored cylinders
and more.
Before removing the head to inspect...make sure the easy stuff is double checked first!
Mas
samo_ott
Wow... I've hardly ever run an engine newer than '77 either. I run 50's and 60's engines daily in the summer... You guys must have a lot of extra cash over there!
Before we get carried away and I cry, what is the right way to do a compression test
aerobat
we do not have cash for fuel ! currently 1.70? or rougly 2.25 $ per litre ! :mad: i want prices like you have in USA...
@seahorse : warm up the engine , make sure you crank from a fresh battery , give WOT ( but without gear !) , crank until no more rise in pressure occours . look if the cranking speed seems normal or slow ( to exclude a weak starter or poor electrical connections)
samo_ott
I want prices like the USA also... we're currently $1.30/litre
hopefully that is the problem. Waiting on the impeller so i can not warm the motor, nor was i aware of wot, thanks.
HighTrim
Doesnt have to be warm nor do you need to adjust the throttle to WOT, will make no difference whatsoever. If you dont believe me, try it.
