tmarston2010
Thread starter- Joined
- Apr 8, 2012
- 12
I picked up this 1956 Johnson 5.5HP Sea horse motor. The model is a CD-13A. This is my first motor restoration. I currently have a 12 V-hull that I put mahogany seats in and I also made the transom with mahogany as well. I ran it with a sears gamefisher 3 HP but its just not enough, especially in a river.
I got the motor off of Craigslist for $125 the owner said it hadn't run in 10 years. It seemed to have compression when I pulled the string. The major flaw is that the lower end had a small hole in it. I had to take the majority of the motor apart to give the lower unit to my welder to fix the hole. That has been finished and I have been slowly picking up part to put everything back together. I have a new water impeller, power head gasket, and the lower end seal kit is showing up tomorrow. Once the lower end is back together and installed I plan on spraying the whole lower half and the repainting the cowling too. I'm just keeping my fingers crossed that she'll turn over when it is all said and done. If nothing else I am certainly having a lot of fun working on it.
