1956 evenrude 15 hp
papasmerf01200
help my motor hasnt run in a couple of years now cant get it started help i played with carb settings did i goof up what are they?
JB
Re: 1956 evenrude 15 hp
Howdy Papa.
Welcome to iboats. :)
Go to the Engine FAQs Forum and do "Awakening a sleeping outboard", Then "Outboard won't start", if needed.
Good luck. :)
cougar1985
a good generic base line for carb setting is 1 turn out from lightly seated.some models will say 3/4 turn some 1 1/4 so thats why i said GENERIC base line.if it runs then you adjust from there on both high and low ,preferably in the water under load.seeing as how it hasnt run in a few you might want to find the thread " awaking a sleeping outboard".remember thats a 24:1 mix motor not 50:1
