1956 30hp idle circuit
pc40chas
1956 30hp evinrude: starts and runs at high throttle, slow the throttle down and u get lean pops and stall. all new seals and rebuilt carb except the float it looked good. it seems to be a timing issue but im not sure. any suggestions?
pc40chas
Re: 1956 30hp idle circuit
thank you for the reply so fast, we tried that and it still dies out. i called it a lean pop and maybe its not a lean pop . im new at this old motor thing, its almost like a small backfire then it stalls. i have a friend that knows motors and he is stumped too. we took the carb appart to double check and it SEEMS fine.
F_R
Honorary Supreme Mariner
Have you even looked at the ignition system? Those motors all have bad coils unless they have already been replaced.
wbeaton
Check the ignition and flywheel key as suggested. What is the compression like? Actual numbers please.
pc40chas
thanks for the replies again, hopefully i can check those out today
