1952 Duracraft Sportsman
m casey stock
Re: 1952 Duracraft Sportsman
LOL.....I know what you guys are thinking.....HEY!!!! WHERE THE HECK ARE THE PICTURES!!!! Well it would not have been as much fun to put them in the same post. I also want to tell you something else about the smaller one. Meanwhile here are a couple shots of the Chris Craft.
jbcurt00
Your killing me smalls ^^^ Still no pix :facepalm:
m casey stock
LOL, I had to swap to my PC because I couldn't see where to add the pics from my phone
. then I had to email the pictures to myself to put them on my PC. Here are the C/C ones.
m casey stock
Dang, I usually don't have problems with this, but I am really having issues tonight, sorry. I have no clue why that one picture posted sideways either. The big thing about the secound boat is that it is Lag bolted to the wall through the hull with about six monster bolts Uuuuuugggggg!!!!!
m casey stock
the last of the pictures.
This is such a cool boat to have this life, literately "screwed" to a wall. The bottom of the hull doesn't look like the planks on the sides, I think it is plywood somehow molded in that nice smooth rounded shape. Wonder how that was done?
jbcurt00
Kind of reminds me of seeing the unique & somewhat rare tin boats that survived 50+yrs unharmed, just to be modified, what could have been a generic hull transformation, into a fishing boat............. :facepalm:
I know, I know, it's YOUR boat, YOU can do whatever you want to it. I also understand that your grandfather's boat modified is still your grandfather's boat..... So WHY don't you leave it alone or pass it along to someone who appreciates it just the way it was made, and find a cheap generic tin boat to cut up?
Ugh:
attachment.php
Casey, you weren't as lucky as me to find a Duracraft that wasn't yet assaulted by a sawzall, but I couldn't imagine cutting & modifying mine....
If we don't 'save' them, who will?
m casey stock
So true, So true. I feel the same way.
jbcurt00
I believe a great deal of the wood boats made just before the fiberglass craze were of molded plywood bottoms & 'real' wood lapstrake sides & topsides. Particularly the wood boat kits.
Somewhere I seem to remember reading that wood boat makers saw the dwindling supply of mahogany & teak and began the cost (and material) saving practice of using plywood where the customer & anyone looking at the boat wouldn't know any different. Not really sneaky, just keeping the costly 'good' stuff for the visible areas.
Plywood gently bent in multiple planes/axis becomes quite rigid & will hold it's form quite well when properly fastened. I only used 1/4" luaun for my knock down 3pc boat and the fore & aft sections are quite sturdy. The larger center section is a tad too wide & long w/ not quite enough camber in any 1 pc of ply, so it's tricky. In the water, it displaces such a large surface area that the 'point' load of stepping into it w/ 1 foot stresses the hull's bottom along it's perimeter frame. I counteract it by having a 2nd layer of ply resting 'loose' along it's interior, spreads the load just enough to be manageable. Once seated or kneeling, it's no longer a problem....................
Ken Simpson (designer of my knock down) and other designers of stitch & glue hulls really make the most of plywood's flexibility.
I figured you'd agree about the cutting up tin boats, I remember the dash rebuild early on @this build...............
You've got a glasser
You've got a tinny
You NEED a wooden boat....
If you don't want to make a late night road trip to pull the stakes outta her hull & save her any further shame & embarrassment:
attachment.php
I HIGHLY recommend a plywood stitch & glue or modified stitch & glue (like mine, although there was no stitching)
m casey stock
Yea, I don't think I could get away with it or I might would try LOL :ballchain:I do have some aspirations now to find and old woody to restore or maybe go with my original thoughts of building one from scratch. I'm not sure I can duplicate that nice rounded curving hull without fabricating some elaborate jig to mold the plywood with. I noticed no port to starboard ribs, only a few support or stiffening striingers from bow to stern on the boat and I like that. There had to have been something that was used during manufacturing to create those bowed out curves that held that shape all these years without anything to support it. Just beautiful (to me anyway)
xjdriver
I don't know about Casey's, but mine couldn't have been for that. The fixed bench back wouldn't allow you to reverse the seat back, since the straps on mine are on the front of the bench.
The reversible seat was an option on some 50-60's vintage boats, I'll see if I can find a pix...
Be back....
EDIT:
So maybe mine has a different models bench seat & the Duraflite Custom's seat back??? IDK. Hard to say..
Turn signals? Lol
jbcurt00
What the heck?????? LOL I'm not sure we are talking about the same thing :noidea:
I think XJ was referring to the pix I posted. The '57 Chevy looking fins end in what could be turn signals. Bottom right boxed in white:
although we were discussing something else, the reversible seat backs
m casey stock
I do have a couple pictures of my latest "piddling" in preparation for warmer, dryer weather. I have my hardware mounted and secured in the rear section and the carpet glued down in the center section. Still waiting on my seat cushions.
xjdriver
Na, read were it says "functional tail fins".
m casey stock
Actually I knew what you were referring to, it just came out of nowhere since we were discussing removable/reversible seat backs. I guess fins are okay, there are some that look good on the right boat, like this one
but mostly I don't like them. I appreciate the style though. Some might say that my Duracraft has "fins" (if you look from the rear) but I wouldn't say that it does because they don't rise up from the gunwale from the side veiw. As for what is meant by "functional tail fins"? not sure, could be that they have some lamps that just light up with the rest of the running lights or maybe that they help keep water spray off of the passengers. Anyway, thanks for the comment, maybe you can look into it deeper and let us know.
xjdriver
Ya, lol I just thought it was strange. Ill go back in the shadows and await the splash. Will it be happening soon?
m casey stock
Gosh I would love to say yes, but I don't know. Things got colder/windier/and wetter sooner this year than most. We usually get "our" winter after the first of the year. If that perfect winter weekend pops up, then, you betcha! it's gonna happen!
ssdale
Starmada Splash of the Year 2016
Super Job with your Duracraft! Love the style and the buffed aluminum is awesome!
m casey stock
Thanks Dale. Nice Job on your Mckenzie too and I look forward to seeing things happen with your Starcraft.
