18' Starcraft SuperSport restoration
Status
Not open for further replies.
ezmobee
Re: 18' Starcraft SuperSport restoration
thanks irishmedic. I forget but will measure it for you and post back. I've also completed my bow insert w/ pedestal and will post pictures of that!
MichaelP
^^^^^^^^^^^^ Ditto. EZ Did you push that splash well back like Fishinho?.
ezmobee
Spent all day Saturday on the wiring. I was going to half-a&& it just to get the gauges working but was talked into going all-in by Tim Fives. The day started by going to a local marine dealer to get a rectifier for my engine. I tried to quickly hook up my tach last weekend and it wouldn't work. Volt gauge also stayed at 12V when running so it was looking like my charging system wasn't working. Signs pointed typically to the rectifier which was a $35 part. It worked! Next went to buy some wire where it became apparent to Tim that I was going to lamely wire up those gauges. Somehow I ended up leaving there with some 4 or 8 gauge (I forget) for main runs to a fuse block, and a number of other spools of 14 gauge for everything else. Stopped at another marine dealer on the way home to get a fuse block Tim had seen there previously. I spent all day on this project. What a pain. But it was worth it. Got all the wires properly run for the fuse block and my accessories: lights, bilge, horn, etc. Got the gauges wired to all their appropriate sending units. I also finally installed the combo GPS/fish finder I got around Christmas time.
At the time of purchasing that awesome multifunction gauge I was bummed about not being able to find a matching tach. So I just ordered a stardard teleflex one. Well I had no idea both would light up red! Sweet!
Fuse block
Took it out yesterday for a fun day with my son, Tim, and his two kids. We had a blast. Went to a smaller, shallower section of the river that I normally only go to with my dad's little boat. However, I have seen larger boats there but was too cautious to take mine. Finally took the plunge and it went fine. We managed to find enough good water to run around in have a nice ride. Deepest part: 8' ! We did go up river a bit too far and definitely found out where you don't want to go. We were going super slow though so no permanent damage. I think I have a pretty good handle on the navigable portions now and will not be afraid to go back (unless it continues to not rain!)
My now working tach showed my WOT RPM with that load to be 5300. Can't complain about that. Near perfect actually. So that confirms that I will be replacing my beat prop with one of the same pitch. We also ran around a good bit with the top up and it went fine. Best part was that GPS/sonar. It is the first sonar I've had yet that actually accurately read the depth when on plane. So handy!!!! especially in that stretch of water. I didn't get a chance to really play with the mapping functions but it seemed pretty cool. Showed my speed and coordinates, and even knew the names of all the islands on this little po-dunk stretch of river. I'm super pleased with that thing for the price. http://www.cabelas.com/sonars-eagle-cuda-350-s-map-sonar-gps-fish-finder-1.shtml My trim sender isn't working and my temp sender doesn't come much off the lowest reading so both those things will need some troubleshooting.
Huron Angler
The gauges look great, and the fact that they work and both light up red is a real bonus:)
Your boat sure floats level, that probably helps the performance a bit.
Have fun with that sonar/gps...it will let you get into those shallower areas that might not have as much fishing pressure.
Speaking of fish did you see any? Make sure to set waypoints when you mark the big ones:D
sprintst
Great looking work man. My gauges are farmed in for now until I replace the dash. Yours look pro.
I did the same on the fuse block and am glad I did it. So much easier to maintain and neat...
yooperangler
Nice work Ez gauges look great and so does the boat in the water. I really like the fishfinder gps makes me wish I hadn't bought the one I did allready. Nice to hear about one that actually works at plane as I've never had one that does. I may need one of those for xmas.
ezmobee
Thanks guys. Real big weekend for the boat coming up. Headed out to Lake Raystown again for the weekend with Tim Fives, a friend of his, and our friend Todd (yorkboater on here). Taking both Tim's boat and mine. Can't wait!
jasoutside
She looks great sitting in the water there man!
yooperangler
Glad to hear your getting her in the water a lot. I keep looking at that pic with your top up and that is just perfect. Shade, plenty of room to move around and looks great.
GA_Boater
EZ the sonar/gps looks like an awesome deal, especially for the price - good find. Love the dash! Need fish pics. LOL
silveraire
ez, on my way to cabella's in hamburg to pick up one of those gps/sonar units. To good a deal to pass up. I think they should give you comission on you sales here. lol. boat is in the shop now getting a few things done to her, then I hopfully will see ya on the river.
tight lines,
chad
Bighoss
Yup me too. GPS and finder under $200? Might as well copy the entire dash from you. Headed to Dundee.
ezmobee
You guys can thank cheapboatkev for the GPS recommendation! I received a very nice Lowrance fish finder for xmas from my dad but I ended up exchanging it for the Eagle unit on Kev's recommendation.
Triton II
Ez, she looks really good, nice work on the gauges and the electrical. :D You're an Eagle shareholder I take it? :p
TII
archbuilder
Hey EZ, she is looking really sharp! Its amazing how much wire it takes to wire one up! I kept buying and buying wire! Enjoy I'm heading out to the lake for 4 days tomorrow, looking forward to it! Keep up the good work!
saxrulez
EZ the boat looks phenomenal. If you ever decide to sell it, make sure you let me know. It will go to a great home. I am serious too.
Seriously.
Great work.
ezmobee
Seriously.
Great work.
Thanks! This boat is going with me to the grave though I think. (I make no promises on outboards though :p)
saxrulez
Darn. I was just seriously thinking about, "what if he would sell it" and planning on arranging delivery/pick up.
I love the boat man. Fabulous work. I guess I'll keep plugging away at mine. I've been saying I'm going to put nautolex down all summer, but my work schedule got crazy. I may sneak order a bimini top this week and just take the verbal abuse from my wife. She'll love it as soon as we take it out with it on. Where did you order yours? It looks identical to the one I've had my eye on.
My wanna do list is bimini, nautolex, and create some side panels covered in nautolex with rod rolders on them and storage behind them. I'm moving in a few months and will have a real winter in Kansas(AND A GARAGE!!!!). Hopefully get all of that done this winter.
Status
