17.5' Hourston Glascraft stringers
caribear
Hi all. I have a 1977 17.5' Hourston Glascraft hardtop. I need to install an 8" inspection hatch in the deck as I believe there is some water in the hull. Can anyone tell me where the stringers are located under the deck so I can get a rough idea of where to cut the hole. Many thanks.
Re: 17.5' Hourston Glascraft stringers
Ayuh,... Generally speakin', the fuel tank is centered in the hull, if it's a single tank...
Stringers will be on either side of the tank...
Yacht Dr.
Hello Caribear and welcome to Iboats :) ..
Its kinda simple actually :) ..
Find a spot that you think your going put the pie plate..
Take a hammer and kinda tappy around that area... You should kinda hear a hollow sound here and there and then you might hit some ' Thud ' sounds ( kinda feels/sounds solid ).
So when you Think your kinda 5" away from any hard spots all the way around your tapping..drill a small 3/16-1/4" hole very slowly just until you break through the decking.
Now here is the Cool trick.. take a coat hanger and snip the hook off. Flatten the wire out to a manageable size enough to make a "smashed Z". Your first bend is 5" ( this will go down into the hole you just drilled ) then up a little and then another angle bend so you can rotate the thing in the hole.
Your basically making an inside compass to see if your going to hit a bulky or stringer.
Stick that baby down in the hole and Spin the hanger 360 deg. .. if you hit something then re-drill over a bit. ( remember that these little drill holes are going to be cut out of your 8" hole so you should have some wiggle room to move your pilot holes a few inches.
I hope you know what im saying here :) ..
YD.
caribear
Thanks Yacht Dr! That's so brilliantly simple I almost feel stupid not thinking of it myself! Now, if I can only find a wire coathanger....my girlfriend doesn't allow them in the house!
Yacht Dr.
Go ask the next door hotty that sun bathes out in the lawn .. or does your GF not like that too ;) .
Glad I could help man..
YD.
