Re: 16' Nescher ski boat complete restore
Arch I've been following your "redo" since day 1. If I may make a suggestion regarding your seating arrangement. I have an 18' ski boat with a 140 hp O/B (Johnson), the bottom is almost dead flat (a copy of the old California Drag/Ski boat design), It has an 18 gal. gas tank mounted under the front deck, the seating arrangement is like this, Bucket type seats facing frontwards,(same as most boats) there are a "bucket" type seats, (attached to the front ones) facing back towards the transom, (same as most boats). The boat builder then extended these seats approx. 4' down the sides of the boat(almost to the motorwell and the transom the backs are of couse upholstered. There are probably hundreds of boats with this seating arrangment. Now keep in mind with the gas tank upfront, the weight of your passengers being towards the front your boat would easily get on plane. Its been our experience with a merc that they seem to want to "rev" quite high before actually get the boat up on plane, now add to this your gas tanks being at the bank near its transom plus any passengers sitting (dead weight) back there I don't think you'll be happy with the way your boat will perform, lack of acceleration, the continual "porposseing) unless at full or near full throttle. Just a thought, take for what its worth.
By the way when using are boat in the skiing mode it will nearly stand on its transom when you first accelerate sometimes scaring any 1st time passengers
Bailey
