150 hp water pump
angler00
How tough is it to change a water pump on a 2000 150 hp ocean pro ??? never messed with a outboard motor. I do have a manual for the motor.
Since you have the manual, it is not hard. Read the procedure. Drop the gearcase. Read the procedure again, while looking at the gearcase. Then begin the repair. You will need some Permetex Aviation gasket cement, some silicone caulk and some marine grease. The key that spins the impeller locks(actually jams) into position.
angler00
what I am worried about is getting the shifter rod in right, is there a trick to make it a little easier to connect it??
boobie
What manual do you have ?? It should tell you about that in it.
angler00
manual I have is a selco it doesn't really show how to connect the rod goes through the steps and not real clear on that also.
guess in time will figure it out thanks
If that motor is like my 1998 J150EXECD (likely), there is a clevis pin under the carb, in the shift linkage. Shift motor to forward and pull that pin and slide the linkage toward the powerhead to release the shift rod.
Shift rod height is 26 1/4 for a 25" shaft, but you should not mess with it if it is shifting properly.
