22 year old DP-SM advice
stouchton
My outdrives (2) are 22 years old and have never been rebuilt. I did replace boots 8 years ago - my universals could not be greased so I saw no reason to pull them off periodically after that. Even my gimbal bearings are original. For personal reasons I just ran the boat to escape life (wife was terminally ill).
Last season I heard a bearing rumble while in gear on the port outdrive. I did find a tiny amount of water in it end of this season. So figured I have a bad bearing/race in that outdrive. Starboard has no issues. I will be bringing both drives home tomorrow.
Question 1: I will be rebuilding the port outdrive (I have done many car differentials, so I understand what I am getting in to here). Should I rebuild the starboard also or simply just reseal due to age?
Questions 2: My cone clutches work fine. How do you know when to replace them?
Question 3: None of my bearing/race pullers/drivers are long enough to work so I will need to source the VP tools. Is there a source for used or alternatives? I scoured the auction site and found nothing.
Last question (for now...): Is there a cross reference somewhere on the web from VP part numbers to Timken/SKF? I did not find much searching the web.
I appreciate any insight and help you might have.
Get a FACTORY manual
Most likely the bellows let water in and the input shaft seal and bearing is all that is needed
Do a pressure test and a vacuum test
Kosmofreeze
Curious to know how many hours your 22 year old DP-SMs have accumulated? My 25 yo DP-SM just clicked over 400 hrs (yeah, I know ... it's just broken in!) this past season. I average about 30 hrs per year. The boat is fresh water only and "lives" on a trailer. I'm wondering how the effects of time compare with the effects of in-service hours on these drives. I replaced the bellows a couple years ago ... the old ones still looked brand new. The log book suggests the gimbal bearing was replaced in 2011 at 200 hours. Can these "gently used" drives last another 20-30 years? Where's the best place to spend your preventative maintenance $$$ on these things?
My 1988 290DP has about 2000 hours on it. It was pulled apart twice from me to repaint
These drives are used on 40 year old water taxis. 10,000 hours is common between refresh
Like asked about, how many hours do you have? Do you keep up with the recommended maintenance?
stouchton
I do have the factory manual, so should be good there.
The bellows on both outdrives had water in them - but no sign of a tear in the bellows? Hopefully you are right about the input seal and bearing. I did pressure/vacuum test the beginning of the season but could only spin the engine to test input seal. I like your idea of checking it now that the drive is removed and I can really wiggle the shaft.
My port gimbal bearing was in pretty bad shape. Starboard was surprisingly good. Universals were also still good. I am planning on rebuilding them with greaseable spiders.
stouchton
I have 560 hours on mine. As far as bearings and gears go, this is really low hours. Water/corrosion is the enemy. I learned the hard way when I let my Camaro diff sit for 10 years. The upper half of the carrier bearings corroded - I had wrongly assumed the gear oil would protect it. So now everything moves a couple times a month.
stouchton
560 hours, oil change end of every season, Vac/Pressure test every time, new o-ring seals every time. I got lazy on the bellows for the reason stated before. I enjoy working on this kind of stuff. Got lucky 8 years ago, used a lot of grease when assembling. The drives literally fell off. Now I have to remember which grease I used! These suckers are heavy. Felt like I was lifting a couple hundred pounds into the bed of the truck. Probably not that much, I'm just getting old.
BRICH1260
Pull the drives and plan on replacing the gimbal bearings and bellows, obviously along with the drive oil. If no water in the oil, put it back together and you should be good for a few more years.
Lou C
With the bellows they can look new but the rubber ages and gets stiff just like a car tire does, spread it at the folds and look carefully, if you see cracks then it’s time because sooner or later one of those cracks will open up and let in water. I have had the OEM Cobra bellows (which Volvo actually used in the early years of the SX) last easily 10 years. The one on there now, I am going to check when I pull the drive soon and if I see any cracks I have 2 new Cobra bellows sitting on my boat parts shelves in the garage.
My Cobra drive is 38 years old, unknown hours, it has had no major work in the 24 years I have owned it, the only repairs have been a few seals (normal maintenance). I did have to rebuild the trim rams and replace the ram rods due to corrosion. If you keep water out and always change the gear oil most outdrives should last easily 30+ years. If your bellows does not leak, a gimble bearing just does not wear out at least that’s been my experience.
Horigan
@Lou C , Aren't you worried about the "new" bellows aging on your shelf? I'm running the same Cobra bellows and it's been lasting eight years so far with no signs if minor cracking. I'm debating on my next bellows on whether to go with the softer Cobra bellows or go to the newer and stiffer Volvo SX bellows.
Lou C
Not really because when you buy one you have no idea how long it’s been sitting in a warehouse somewhere unless they have a date code. If it’s wrapped up not exposed to light I would not worry.
Lou C
I have wondered about that stiffer VP bellows too, wonder if any users here have had experience with both.
stouchton
My main bellows were the new stiffer ones. Been on there 8 years and obviously failed. Boat is in fresh to brackish water, in the bay from April to December (pulled in Nov this year to remove drives). My exhaust bellows are the old soft ones. I stretched them all out and could find no issue.
stouchton
So leak testing revealed the outer prop shaft seals on both outdrives are leaking. Initially I did not have to wiggle them and they leaked bad at 10psi. After sitting overnight they decided not to leak??? Wiggled them all around and no leak. Shifter and input seals did not leak.
I am going to reseal both drives. Drive shafts are off, cases split and so far I have removed one prop shaft retaining ring - the other is putting up more of a fight but I have not gotten serious about it yet.
So far all bearings in the outdrives seem fine. Hoping the noise was from the horrible gimbal bearing. It only did it in gear though.......
Lou C
Did you water in the gear oil when drained (lighter colored streaks)? If so there is a leak but finding it can be tough.
