22 year old DP-SM advice
stouchton
My outdrives (2) are 22 years old and have never been rebuilt. I did replace boots 8 years ago - my universals could not be greased so I saw no reason to pull them off periodically after that. Even my gimbal bearings are original. For personal reasons I just ran the boat to escape life (wife was terminally ill).
Last season I heard a bearing rumble while in gear on the port outdrive. I did find a tiny amount of water in it end of this season. So figured I have a bad bearing/race in that outdrive. Starboard has no issues. I will be bringing both drives home tomorrow.
Question 1: I will be rebuilding the port outdrive (I have done many car differentials, so I understand what I am getting in to here). Should I rebuild the starboard also or simply just reseal due to age?
Questions 2: My cone clutches work fine. How do you know when to replace them?
Question 3: None of my bearing/race pullers/drivers are long enough to work so I will need to source the VP tools. Is there a source for used or alternatives? I scoured the auction site and found nothing.
Last question (for now...): Is there a cross reference somewhere on the web from VP part numbers to Timken/SKF? I did not find much searching the web.
I appreciate any insight and help you might have.
