Intake manifold, 350 GM
Lou C
Good LORD that looks way worse than any part of my raw water cooled motor used in salt! don't know if that could be saved with rust converter, might be worth removing all the loose rust, then poke at it with a pick see if there is still solid cast iron there.
Normally a rotor just pulls off but I see 2 hex headed screws there maybe those have to be removed?
Merc guys what say you?
jimmbo
While this may or may not be a GM Distributor, Rotors on GM Distributors, were almost always secured with screws, as they sat on top of the Advance Mechanism
rickasbury
Ensign
It is a gm distributor. I see at least one hex bolt holding it in. The timing on this motor is not adjustable so it has to come out and go back 100% correct for sure...
Lou C
The last time I had one of those, was our '75 Olds, 5.7 with a Quadrajet
I think I had to change the HEI module once in the 15 or so years we had it.
Lou C
Before that we had a '72 Chevy Impala 5.7 with points, I had to climb up on top of the engine to change the points. God forbid you dropped one of those screws in the distributor! GM did have that nice allen key adjustment for the points, you could set the dwell with the engine running.
manually rotate the motor to TDC on #1. use a paint pen. mark where the rotor is before you pull the dizzy. then when you pull it, the rotor will move. mark where it is when it stops moving.
installation is reverse. but there are markings on the dizzy body and pics in the manual.
Scott06
Many days..I will need to pull the rotary to full assess and hopefully repair. I understand how a rotor works but have never pulled one...can someone help me with this so I don't screw up the timing? I'm fresh water cooled..water is apparently coming from the pedestal base over the enging compartment...2009 350 mpi 350 mercView attachment 421045
No reason to worry that’s surface rust. If in fresh water you have water coming down from swim pad or deck above. Do you still have the flame arrestor cover on it ?
you will sell the boat before that rusts through.
rickasbury
Ensign
That is old school lou for sure!
rickasbury
Ensign
I could only hope but that is not my luck! Plus, it should not be a big deal to pull it? Can I mark the intake and the rotar and put it back the same as long as I don't move the crank?
rickasbury
Ensign
And yes the arestor and such are all there..
rickasbury
Ensign
Im just seeing this and will look again am..thx for the help.
Scott06
Yes but it were mine I would wire brush and paint the intake, and call it a day
Lou C
Get some rust converter from Eastwood & after removing all the loose rust coat it with that and then prime & paint. You just have to neutralize the rust.
I would get it sand-blasted then epoxy coated. the original e-coat on the intake simply sucked. it was ok for the factory floor, however was fairly porous in nature and allowed rust to build up.
rickasbury
Ensign
I watched a really good youe tube. Some one that had the motor out doing what ever work, but posted specifically removal and re install...lining up TDC on the compression stroke, with the rotor pointed at cylinder 1 cap position, no adjustment for timing. I really don't think I need to pull all the plugs, belt etc so I can do that TDC thing...If i mark the intake and the rotor tube for alignment, mark where the rotor is pointing, as long as it goes back the same. Would there be any tension on the motor that would be relieved when the rotor gear separates? Other than that, I would not understand the need to move the crank around..
Lou C
The process of doing that is confusing because unless you have a way of ascertaining that both valves on cyl #1 are closed, you're not sure that you are at TDC of cyl #1 compression stroke. You could line up the TDC mark and the rotor with #1 and it could be 180* out of phase or on the exhaust stroke. Remember the cam turns 1/2 turn for each turn of the crankshaft.
If I were doing this, another way to know is to hook up a compression tester to cyl #1 and you'll see the compression rise when it brings the piston to TDC on the compression stroke with both valves closed. If one is open compression won't rise.
I recall having to think this through when I replaced the heads on my 4.3 years back but it was easy because I left the valve covers off since I had to set the hydraulic lifter preload anyway. That way I could see clearly when it came up to TDC on #1 and both valves were closed.
no tension on the cam gear when you pull out the distributor.
be careful doing this, it's easy to get confused!
If it were me, I'd get all the rust off that I could, and coat it with Eastwood's rust converter and prime and paint. I don't know if it's worth pulling the distrubutor and intake to do that.
alldodge
I would suggest
Rotate motor until rotor aligns with notch.
Remove/replace things, then install distributor so alignment marks align as before. Doing it this way the Distributor does all the aligning and it makes no difference where everything else is
rickasbury
Ensign
Thanks! That is a really good tip on TDC on the compression stroke...that's going to help some people who did not think of this like me.
That being said, and maybe I'm just trying to convince myself, since all I'm doing is pull it out , cleaning/painting reinstalling. The engine is not going to budge, no other repairs. Even if I'm only kicking the can down the road a couple of years. We need to get on the water as for other reasons we have used it very little over the last 6 years. There is no room to do anything around the rotor without pulling it. With the whole rotor asy out. I don't have anything to really point it to right? Once I have it out, it it turns inside the tube then I'm screwed...if I've only marked the tube and the intake...ah, but that's what I belive you are saying is to align the rotor ro something in the asy...as below was offered...starting to make sense, scary..
Lou C
When you have it all lined up before you pull it out you make a mark on the distributor body that lined up to where the rotor is pointing. Or when you still have the cap on the distributor find the receptacle for the #1 plug wire in the cap and make a mark on the body of the distributor straight down from it. That way you always know where the rotor should point for #1.
