'77 Holiday Transom
N1265
What is the best way / tools to use to get them finishing nails out of the Transom cover without bending it all up ?
N1265
where can I get the splas hwell drain tubes and do you need a special tool to install them ?
MikeSchinlaub
Ensign
Try a plastic panel tool to get under the splashwell lip. If you can move the nail head out just a bit, you could grab it with some vice grips and pull it the rest of the way.
If you get the plastic ones, all you have to do is cut the tube to length. If you get a brass or aluminum, you would need to flare the outside. I've only used the plastic ones.
N1265
Do I need the ones for a 1" hole or 11/4 "
