Follow the fuel input hose to the fuel pump attachment point.....look at the hose below it.....I see what looks like that connection is bad.....replacing the hoses is a good place to start. Wiring seems to be in good shape.
Thanks, I'll look further into it this winter. I need to get back to more pressing projects. I mainly wanted to verify the motor had good compression to know if I should just part it out or not. But I'll give it a chance to live again.I assume you tested for power at the #2 coil primary? A standard voltmeter may not show the quick pulse that fires the coil.
You might swap coils and see if spark returns to #2. If so, replace the coil. If not the stator or CDI unit is likely bad. There should be ohm specs for the stator.
I bought this:I just bought this stuff
To make a dva , only need one of each but minimum buy is 10 or 20 , whole lot cost about 12 bucks , as opposed to 80- 100 to buy one .![]()
Yep thats pretty much what Im wanting , damn ,I didnt see one for that price thoI bought this:
.Amazon.com: Electronic Specialties - Leads (640), Factory : Industrial & Scientific
Buy Electronic Specialties - Leads (640), Factory: Test Probes & Leads - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
Will that do the same thing?
you shoulda bought the flux model....in but the capacitor is bigger that I expected and wont fit in the box .
Yes, I took lots of pictures as I removed things. It screwed into the bottom of the cover that was over the carbs.Hopefully you have a Factory Service Manual. If not get one, as it will have the correct procedure for the Link and Sync, as well as many other Specs and Procedures.
On the last pic you posted, it shows a Hose coming from the center Crankcase, with the other end having a threaded Fitting. Any ideal where it screwed in to?
Yeah, but it needs 1.21 gigawatts to work.you shoulda bought the flux model....
