MikeSchinlaub
- Jan 14, 2025
- 1,005
Now you're getting it!@Drivewayboater2 This is not gonna be cheap....
We should all embrace the darkside.Now you're getting it!
It comes with unlimited power.We should all embrace the darkside.
but, that is fixable i'm told....Just don't grind a hole through the boat!
You have to finesse it a bit. As long as they aren't very deep, you can go back later with 36 by hand and smooth the sharp points. Or do a light coat of resin putty over as you glass.@MikeSchinlaub the problem is with that 36grit flapper disk it makes dips super fast in the fiberglass mabie i should switch to a electric hand sander to flatten everything out or take off that layer
Yes, but no need to add body and paint work to the list.but, that is fixable i'm told....
Yea I was teetering on it, I had a couple sheets of aruco plywood left from a project i just finished up so i decided on the cheaper route. The composite guy at the airport im at could have orded me 2 4x8 sheets for just over $200 each free shipping aparently hes a high dollar client for the composite materials supplier so they get him whatever he needs free shipping.You're doing great. As I'm late to the party, my only advice would have been to use Coosa. I missed a spot on my transom 13 years ago and just got a new Coosa transom in place.
At the end of the day you can be very proud of what you've accomplished.
<GULP!!!>could have orded me 2 4x8 sheets for just over $200 each free shipping
