What is the correct name for this breaker?
alldodge
Yes, with caveat, there will be no issue so long as nothing shorts out. My guess is nothing will. You will know if there is a problem by a big a$$ spark when wires connect together, little spark is ok ;)
To clean all the contacts is about 2 hours of work with a wire brush and sand paper. You are focused on two of potentially 20 connections.
I would start now, and be done in 2 hours or less
Gee, wire the bilge pump directly to the battery, thru a small inline fuse if you have one. A bilge pump, even if it shorts out shouldn't cause a fire, unlike other stuff on a boat. Also, they are often directly connected to the battery, whereas the rest of the stuff on the boat is always fused to prevent fires. Don't jumper or bypass the breaker. Breakers are there to protect us.
crazy charlie
Upon closing up I think I confirmed the breaker needs to be replaced. When I hold the reset red button in everything works as long as the button is held in and when I let the button go ...nuttin.
Replace with a marine-rated circuit breaker. They should last longer in the marine environment and should be spark protected.
crazy charlie
I planned on getting a dupe of what I'm taking off. I assume it's marine?? Look at the pic. although the back was open which I assume marine would be closed .Charlie
alldodge
The pic in post 2 is a marine rated breaker and is used by VP, Merc and others. Can find them in a lot of places
crazy charlie
ok, got my new breaker.Went with a different style since the current style was open back and not sealed to corrosion. and I boat in salt .I plan to coat each terminal thoroughly with either marine grease or dielectric. There are 4 other small screw heads or rivets.I was planning on brushing on some liquid electric tape to protect them. Also Since both terminals are positive ,I guess it does not matter which goes where on the 2 posts?
One terminal is labeled line, one is labeled load.
The cable coming from your battery switch is the line. The other goes to the load. What brand of circuit breaker did you buy?
The carlings and sea choice have "In" and "load" cast into the housing in really small letters
crazy charlie
I will look again. I bought what was called a pretty generic 40 amp at an RV and marine center.It has an arm and a small reset button next to the arm. Terminals look to be brass( gold) with rubber caps for the ends of the terminals.
crazy charlie
this looks like to one I got except that the lever goes the opposite way.the rest looks identical.Actually if I flip mine upside down it is identical.Probably all made at same factory in China
The blue sea website has the drawing, showing the BATT terminal and AUX terminal.
https://d2pyqm2yd3fw2i.cloudfront.net/files/resources/dimensioned_drawing/285-Surface.jpg
crazy charlie
Nope, I looked with a magnifying glass and no markings anywhere
crazy charlie
New breaker installed and working fine. Had to drill one of the old connections off and the other one just fell off when I was handling it.Cleaned the cable ends and they were too small for the breaker terminals so honed them a bit until they fit.Gonna go with marine grease one the terminals.Them old terminals had black RTV or liquid elect tape on them but still rusted solid under the coatings.Thanks for the help guys!!
Texasmark
Ok ,it's seems like the connections are the issue. Too crusty. Neg on battery and probe on 1 connection reading was less than 1,when I moved probe half inch from the connection 12 came up
Corrosion on contacts (the actual contact surfaces) cause resistance. Current flowing through resistance causes heat....amount of heat equals current squared X resistance in Ohms. If that's the problem, the heat will excite the sensor in the breaker till it's hot enough to simulate a current overload and the breaker will pop.
