Thinking about making a trailer cover... Opinions wanted.
airshot
The real key to a good cover is to keep it taught. Poles, tubes, snaps what ever it needs so no pools or puddles can developed. Covers are designed to shed water, not collect it.
Pmt133
more or less the plan. I'm going to build 2 bows for the bow railing and that should take care of it.
Pmt133
Don't be afraid to modify after a good rain let's you see how well it sheds.
The one I currently use, 2 beach balls are sufficient for the bow. We're in the middle of a long drought so maybe it'll just never rain again. :LOL:
redneck joe
Late to the party.
Sew herself or buy stock. Your call
Either way you want to run ropes from the bow eye, usually then thru the front cleats, crossed over the winshield to the rear ski loops.
Fill milk jugs or make small (one gallon) concrete weights with an eye hook to hang off the edges.
Then get at least one of these
Pmt133
Late to the party.
I mean its like you were... busy or something. :LOL:
I was actually thinking a dehumidifier under the cover and run the tube out the garboard. Kill two birds with one stone. Circulate air and remove the moisture.
Because of the tall bow rail I have to go up and over that. Most of the time with covers this results in little pitch for me. (Bow rail is about 4 inches lower at nose than windshield.) I get by with 2 beach balls or a pool cover pillow laying on the bow. 2 small arches may be more effective in my case vs straps.
The carver I ordered uses belly straps that go side to side. I have a similar cover on the camper and it works well. I think I'll be happy with this.
Pmt133
So I returned the carver for another carver. If I didn't have a swim platform you'd have thought this thing was fitted perfect to the boat. But alas with the over rail mount for the platform I am about 6 inches too short. (Never heard that one before)
So I exchanged for the next size up. Instead of 19' 6" on the centerline and 96" wide its 20' 6" long and 102" wide. I can lose that with strap adjustment I believe. Will report how it fits.
The material itself was quite nice. Light but thick.
