Installing a trolling motor on a 21ft CC
SkaterRace
Master Chief Petty Officer
I have a Blackfin 212CC (pretty much exactly the same as the 222CC they have now) and am looking to install a Lowerance Recon 72 inch on the bow. I've decided on this motor because it works with the Simrad MFD's I have (Go 9's). For batteries I am thinking 2x 36V 50AH lithium from LiTime. When I was talking to the guy who will install it for me in the fall he was origionally thinking of using my bow seating to install the batteries. I was not a huge fan of that because that is literally my only usable storage on the boat.
I do have a deck hatch in the bow though I suspect that isn't dry enough to put them in (what even should go in that hatch? I've never found a use for it) and I have a head in the console which makes installing them there kinda hard. I do have a spot along the side that stores the table which I almost never use. We debated installing them there if the batteries fit.
Past those locations is the stern where on the one side there is an open spot for a water tank - fresh water washdown - that my boat does not have. I originally thought to put them there though he says the wiring would need to be massive and the weight that far back likely isn't good as we normally run with a max of 3 people - 2 at helm and 1 on bench or vise versa.
In such a small center console with limited options, what is likely my best option for putting the batteries for the trolling motor? Also anything "extra" I should ask for to be installed when I get the trolling motor installed?
rolmops
It is very important to have the right weight balance in your boat.
For trailering you need some serious weight on the front end to prevent serious accidents while trailering. Also, with too much weight on the rear you will have trouble with your hole shot because the front of the boat will come up way too much.
If you decide to put the battery in the closed bow compartment you should look sealed marine batteries because the bow of a boat tends to get banged up more than the rear and you do not want a closed compartment to fill up with nasty gas escaping from the batteries. In addition, if you choose the front it is also a good idea to buy a plastic type battery box, so any leakage will be contained.
When I moved the batteries on my boat forward, a cable length of 24 foot with all the turns involved, I used 1 gauge wire. This was for making sure that 50 amps sometimes needed would make it to the starter without overheating the cables.
I added a website that will explain what gauge of wire you will need for what length of cable.
good luck
SkaterRace
good luck
Thanks, yeah the back isn't ideal for weight, though up front the only spot that seems to make sense is in the deck which seems far from ideal. In terms of gas, I don't think that's a problem with lithium batteries?
rolmops
Personally I would go with AGM or EFB batteries. Both are lead acid ,but properly sealed ones.The Lithium ion often need a different type of charger and they are a bit problametic with the charging system on older outboards
SkaterRace
Any space under the console ?
That would be the one spot I said "I have a head in the console which makes installing them there kinda hard. I do have a spot along the side that stores the table which I almost never use. We debated installing them there if the batteries fit." in my OP. It is essentially a storage tray that would likely need some re-enforcement to hold them. For deck space in the console I do not unless you went each side of the head for a battery.
SkaterRace
I have a 2019 Mercury 225XL, and the reason I wanted to do Lithium was to keep the weight down. An AGM based setup would be ~225lbs where the Lithium is going to be ~66lbs. With how small my boat is that weight difference feels noticeable.
I would go up under the seats in the front as my first thought. close to the speakers and under the cup holders and back-rest post
second location would be under the deck in the front hatch area.
would require building a ledge in the hatch area to hold them.
the head area is a bit small, that would be my last location of choice.
what ever bracing you use to install the batteries, remember, these boats in chop are subjected to 3-5G load slamming into waves. so that 36# battery becomes a giant sledge hammer wanting to break your boat.
thats where the front storage would shine. add a bit of foam under the tray down to the hull to hold them and youre golden.
I would lean toward smaller Lithium batteries for packaging over lead acid or AGM.
cyclops222
I would definitely Put the batteries inside of a Black plastic battery box with a matching cover. Put pieces of 1 1/2" square wood pieces around the battery box or boxes. Some Silicone Rubber to bond the wood pieces to hull deck. Install. Ratchet straps over each battery box snuggly. That set up allows servicing acid or LIFEPO4 batteries.
airshot
lifePo4 batteries all the way....best move I ever made with batteries ! Watch the sales, my battery was the same cost as two deep cycle LA batteries and the pull has twice the power and 1/4 th the weight. Run time is almost 3x as long as the LA batteries. Just be sure to use the correct charger on the Lipo batteries, you do not want to mess around using your engine to charge the Lipo batteries!! If you mount them near the front, be sure there is some cushion under the lifepo4 batteries to absorb the pounding, I use a 1" thick foam pad that came with my battery. I know lots of boaters that have made the switch from LA to lifepo4 batteries....not one person is sorry !
SkaterRace
Thanks! Sounds like you align with what the mechanic said. I was hoping to keep it from under the seats as that's my only actual dry storage on the boat. A lot of that stuff though could live in the deck hatch if I could just keep it dry (stuff like shore power cord - can't leave at marina, extra safety gear, and often tackle boxes).
If I was to mount them there, would placing them all the way forward be best (kinda under the tip of the "V")? Or would it need to be more at the back in the hatch area?
SkaterRace
Charling is something I've yet to fully get into as the mounting location will determine how I do it. If I go stern I'll get a charger that can do both AGM and Li batteries so I can have one cord but if up front likely two chargers since I suspect my trolling motor won't burn down that much battery very often. 90% of my fishing trips I'd run it less than 4 hours and based on what I found, the dual battery setup should give me 10 hours or so
SkaterRace
I just went to double check the power and it lasting that long - nope that was for a smaller setup I was looking at for a buddy's boat. Looks like the batteries I found are 50AH and a max draw of 50A so 2 should be 100AH and 100A of max draw with a max pull from the Recon of 58A giving me only ~1 hour and 45 minutes of actual runtime at the max draw. Wonder if going with 3 x 12V in parallel is better so I can get 300AH out of it. Not sure how I'd even mount that many in there though.
the V would be a good area
I was thinking more in the back of the hatch area, under the cup holders myself
one in the V, one on each side under the drink holder.
could also do 6 smaller batteries if you need packaging
or a custom battery pack (there are companies that make custom packs out of the individual cells) I think @bruceb58 even makes custom battery packs using the plastic marine cases that look like ammo boxes.
SkaterRace
I don't recall there being a ton of space back from the hatch. The boat is sealed up for winter, so I can't check, but I think there is maybe 3-4 inches back from the hatch? If they fit sideways that may work. Site says they are ~6.75 wide and ~13 long. Not sure how wide the lockers would be.
That seems like a decent option. Thanks!
bruceb58
I make my own packs but I basically 3D print the case plus some aluminum plate.
There are so many options out there these days, I probably won't make them anymore like this. Was a fun project...it's the reason I bought a 3D printer.
bruceb58
For charging, you can not connect directly to your engine system to charge. You have to put in a DC to DC converter for two reasons:
1) LiFePO4 will pull as much current(up to BMS limit) as you can give it so it would overwhelm your charging system....I recommend charging at the 50% of the max alternator output.
2) When lithium batteries are fully charged, they settle in at 13.6V which is MUCH higher than the standing charged voltage of a lead acid battery of around 12.7V.
How did you get 200 amps with 3 50 amp batteries ?
You are confusing ampacity with amp/hr rating
50 amp/hr batteries will last 1 hour at a 50 amp load
Full shunt amperage is a lot higher
