Grease Seal to Spindle Fit
Weirthit
I recently replaced a warped rotary hub on my tandem axle trailer. Went ahead and replaced the bearings since the cups were pre-installed in the hub, and replaced the grease seal. On the first tow, all of the grease in the bearing buddy blew out of the new rear seal. The seal I.D. is 1.686" and the spindle diameter where the sleeve rides is 1.677 (measured with dial calipers) so no surprise is leaks.
I found a grease seal with an I.D. of 1.62", at least 0.050" smaller than the spindle diameter where the sleeve rides.
Is 0.050" interference between the grease seal and spindle too much? I would hate to destroy the seal surface.
Thanks for any feedback,
Brian
bruceb58
what is the seal number you are using that is too big?
You probably need a 470460, assuming the outer diameter is standard.. That was the seal I used for my axle spindle which is the same size as yours. That number is the same for bot Timken and National.
I am guessing you are currently using a 473336 which is too big,
dingbat
As an alternative, I switched over to a 16735.
The 16735 has a rubber cased, one piece seal designed for power transmission applications, ie. gearboxes, motors, speed reducers, etc.
Overkill for grease filled hubs, but the rubber case helps with any misalignment issues and allows them to be removed and reused after bearing inspection, if desired.
Weirthit
Thank you for the response.
The seal that was leaking is a 168255TB. Same as 470460 per the Timken Federal Seal Catalog.
I also checked the Timken Federal Seal Catalog and the 470460 is for a 1.687" shaft, 0.010" larger than the seal area on my spindle which is 1.677".
I am wondering if the seal with a 1.62" ID is too tight for a 1.677" OD seal area.
Also wondering if I have a mis-machined spindle. Wouldn't be the first thing wrong with this VM Trailer.
Mike_BB
Brian
That's too much interference. You'll wreck the seal or spindle. Your spindle's seal surface is probably worn. Install a Speedi-Sleeve to bring it back to spec, then use the correct 1.677" ID seal. Also, check you're not pumping too much grease into the Bearing Buddy.
bakerjw
IMHO Bearing Buddies are bad news. Grease goes in but never gets to the bearing by the seal.
I am lucky in that my Rockwell axle has a grease zerk at the end of the spindle. The grease goes through the spindle and enters the internal cavity in front of the seal. When you pump in grease, you spin the wheel and watch grease get pushed back out to the front. It also packs the bearings fully. I swapped out my old axle for one of them and never looked back.
bruceb58
The whole purpose of a bearing buddy is to keep the hub slightly pressurized. You properly pack the bearings by hand to get the grease into the bearings.
You don't use the axles with the zerks to grease the bearings. You hand pack them.
jlh3rd
"You don't use the axles with the zerks to grease the bearings. You hand pack them."
well, yes you do if you have that type of axle.
My '06 Karavan tandem has that type of axle and it does a great job of keeping my bearings packed. My hubs get pulled every year for other maintenance and the bearings are well packed.
bruceb58
well no...you don't. Even Dexter, in their manual, says to hand pack the bearings.
If you hand packed the bearings initially and then used the Laz-Lube method with the zerk, of course they will still appear packed since that is what you did initially.
jlh3rd
I didn't feel the need to mention that there is a first time where they are hand packed.
Subsequently, you don't need to.
Don't feel like arguing today. My Karavan's is great, the new grease enters the rear bearing travels to the front bearing and then out. As long as the rear seal is good and you don't use a powered grease gun, everything works as it should.
bruceb58
LOL...when I pull my bearings, I clean them...look for pitting and damage...repack them.
I have seen the damage that using the LAZ-Lube system does. VERY easy to blow a rear seal and if you have drum brakes, you will have no idea.
Kinda like this guy did...used LAZ-Lube on a warm day, spun the wheel...blew out the seal. This trailer was only a year old.20180401_121459.jpg
jlh3rd
if you make more than a couple of pumps and the grease is not moving, then you should begin to suspect a problem such as that, if you have been maintaining it properly. Just because something is a year old doesn't mean it can't be defective or an improper procedure isn't used. I've got an '04 tandem, purchased in 2017, maintained properly, and have a brain. I have not had an issue. Was that trailer checked by that guy after he bought it? Things happen however.
bruceb58
When the hub comes from the manufacturer, the hub is not full of grease. It takes many many pumps of grease to eventually see it come out the front bearing even if the seal doesn't blow.
I never ever use the LAZ-Lube method. I pull the hubs and manually pack them. No need to use it if you do it the proper way. By not using it, there is NEVER a worry you have a drum brake full of grease.
Jeff J
I ruined an axle about 9 months after buying a boat trailer. Whoever assembled the axle at the factory didn’t pack the bearings. They just smeared a little grease on the rollers and dropped them in. When the replacement arrived (warrantied) I pulled the hub before I took it down the road the first time and it had been done the same way.
That person either learned to pack bearings correctly or moved on because 2 years later I had to replace the trailer and those wheel bearings were actually packed.
I don’t use the zerk fittings either. I figure the seals don’t cost much more than a tube of grease and I like the peace of mind of having looked at the bearings and races.
bruceb58
First thing I do when I buy a new trailer is remove the Chinese bearings, replace with US made Timken and hand pack them. On my travel trailer, they get pulled and inspected every one to two years. On my boat trailer, I go a little bit longer since I only dunk my trailer once in the spring and one in the fall and drive 25 miles.
Lou C
I tried the gadget that you put the bearing inside and you grease it with the gun, I found hand packing still works better, tried it both ways when installing new bearings.
On the other hand, I have used the easy lube system for over 20 years and never blew a seal and never had to replace even one bearing! Trailer goes into the salt usually 4x a season. I will replace the seals and inspect the bearings if I feel or hear any sign of a bearing getting rough. Or if it's time to replace a drum brake backing plate.
What I like about the easy lube system is that if there's water in the bearings you will see it right away with a few pumps of the grease gun. And the way you do it, is to turn the wheel while pumping in grease, do it slowly, I have never blown a seal this way.
The other reason why I still use this system, is that hand cleaning/packing can introduce grit into the bearings. You have to REALLY clean them, then REALLY dry all the solvent off and make sure not to introduce any dirt/grit into them when replacing. I always used to worry about that part!
One thing for sure, today's greases are light years better than that nasty smelly yellow fibrous grease (Castrol? Quaker State?) we had in the '70s. I recall doing VW drum brakes and bearings with that stuff and there's still a smear of it in my VW Idiot Book!
We have 3 jeeps with permanently sealed front wheel bearings, they range in mileage from 134,000-->150,000-->184,000 miles and not one has been replaced, even with a lot of beach driving here on Long Island.
I use Lucas Marine grease (blue) it is a calcium sulfonate grease that is one step better than most lithium greases, from what I read....
PS
Lucas Red n Tacky is the OEM grease in some trailer wheel bearings, this is one step above that, from what I read on Lucas's site.
Jeff J
I haven’t seen that gadget. I did meet a guy many years ago who used the needle attachment on a grease gun to pump the bearings full before installing. It seemed like a terrible pain in the rear and about the slowest way I could think of to pack a bearing.
the issue with the lisle bearing packer is you have to clean it between each use which takes about 2 mintues....... where a dab of grease in the palm of the hand takes 30 seconds to pack the bearing and wipe your hands.
