VP 2007 3L 135HP engine oil options
clearbluewater
Can I use regular full synthetic engine oil like
Mobil 1 Full Synthetic
Castrol Edge Full Synthetic
Also for lower end gear oil. Is regular gear oil ok? Any recommendations?
your motor is a flat tappet motor. I would stick with dino squeezings high in zinc, like Rotella T4 15W-40
as for the outdrive, use a marine gear lube that meets volvo's requirements.
clearbluewater
I'm in Canada, I don't know if temps make any difference
Also isn't the rotella t4 a diesel engine oil? Not sure if that makes a difference
BRICH1260
Your gear oil need to NOT to have limited slip additives. Many automotive gear oils do, you need to find one that does not. I use Amsoil marine gear oil.
