So, my 2025 Bayliner VR5 200 hp 4.5L mercruiser STILL barely pulls me up
Status
Not open for further replies.
stakultexsun
So, like my previous post said, (post is closed for some reason).
I've since tried a 3 blade 17 pitch and a 4 blade 17 pitch prop. I can't really tell the difference.
I'm now 210lbs, trying to get up on a slalom ski with 2 adults and one child, their combined weight is like 460lbs, all except the 180lb driver are in the bow.
Takes about 45 seconds or longer to get me up. Trim all the way down, minimal stuff in the boat.
I'm about to try a 15 or 16 pitch 4 blade if I can find one soon enough.
Related side note: All the VR5 bayliners I see at the dealer have a hydrofoil installed. This boat feels like it has about 120hp. If it's just 2 people, 390 lbs cruising in the boat it is just slow as hell, largely due to the bow pointing so high and taking so long to plane.
Here are my "results":
Me and a friend, about 360lbs:
Factory 3 blade 19 pitch:
46mph @ 4800 rpm, trim "optimized for speed"
41.5 mph with trim all the way down 4450 rpm.
0 - 20mph 6.0 seconds
0 -30mph 9.4 seconds
3 blade 17 pitch:
43mph @ 4810 rpm with trim up
41.5mph @ 4450 rpm with trim all the way down.
0 - 20 mph no change
0 - 30 mph 9.2 (no real change)
At this point, I'm not sure what I'm going to do. I don't think I can mentally handle the $30kish I'll lose by trading it in and getting a real ski boat, or a boat that is ~20ish foot with a MINIMUM of 300hp.
I didn't realize that $50k would not buy me a boat that I could ski behind. I've skiied behind 19.5' boats with 120hp outboard, and a 135hp inboard. The 120hp boat pulls me up like this 200 horsepower boat. the 135hp boat pulled me up in like 20 seconds or less.
This is ridiculous. Bayliner should make sure they label this wakeboard boat as not a water sports boat. It's OK for wake boarding and good for tubing, and cruising around, that's it.
Stinnett21
You'll need to be more specific with the props. What are the makes, models and steel or aluminum. Hard to believe the 17 only turned 10 more rpms than the 19 unless they are different prop makes or families. 46 mph is moving out and decent performance for this boat.
Stinnett21
I'm guessing the 19 is the Mercury Black Max. If the 17 was the same I would expect it to put you around 5200 rpms which is 200 over but what you need. This boat is not going to be everything to everyone. On skiing days use the 17 (Black Max), if just cruising use the 19. When going fast with the 17 you'll just have to stay out of the throttle a bit.
cyclops222
Wake boats ...DO NOT ...need to get on plane at all !!
They are to be ...PLOWING OFF PLANE ...at WOT.
paulswagelock
Having the same max rpm for a 19 and 17 pitch prop is a clue, should not be.
Try to get a hold of a 15, same diameter, and see if it finally perks it up.
stakultexsun
Good question, it's an EMP Aluminum and stainless prop. EMP is Engineered Marine Propellers
2ndly, I'm using the data from the mobile vessel view. Regarding the rims and speed, my trim adjustments and accuracy are enough to account for probably over 200rpm differences... I'm also trying to ensure I don't overrev... no doubt I could trim up and get more rpms
airshot
When you go to a 4 blade prop, you typically drip 2" in pitch, not use the same as your 3 blade. You may very well need A prop for cruising and another different prop for skiing.
stakultexsun
Update:
I bought an EMP 3 blade 15 pitch propeller. FINALLY I've noticed a difference.
This was with 3 adults on board, probably 490lbs or so. 2 in the bow, 1 in the captain's seat.
We haven't really timed it, but I estimate it usually takes about 45 seconds to pull me up, this time with this prop it probably dropped down to 35 seconds.
Max speed is about 40mph trimmed for speed, 4750 rpms. 38.5 with prop all the way down, don't recall the rpms.
Gee, a lot of getting up slalom is technique. You can fight the boat's pull, or you can choose to not fight it. Fighting often means not getting up.
When I deep water start, I drag my left foot and try to tuck the ski under my butt. Also, make your torso as thin as possible to the pull of the boat.
You can also jump start, dock start or chair start. These require more skiing skill, but you can get up with less motor power and less fatigue.
stakultexsun
I hear you there.
I tried the other day with only one foot in (front foot..left foot in my case). I couldn't hold my ski straight, but I only tried once and my wife has no clue how to watch me and pull me up at the same time. So when you say you drag it, like it's behind you? I tried to "barefoot it" and didn't want to try the dragging thing just due to time constraints.
I'm actually a very good skiier, I haven't been skiing regularly for many years, but I can ALWAYS get up unless the boat just holds at a steady 15 mph or 8mph whatever it is doing sometimes.
That is when I can't get up, when the boat hits a speed that I cannot get the ski to plane and the boat just holds that speed.
I'll give a typical description of how I get up behind this boat. I'm just going to guess MPH, I may be off by 5 or 10mph.
Left foot in front, right foot in back slot, ski at the best angle I can hold (35 to 50 degrees?). Anyway, so the boat quickly gets me to 5mph, then 8 to 9mph...from there, it takes 2 or 3 to 4 seconds to gain each mph, so let's say it reaches 15 mph I can play with body angle and other adjustments like trying to lean forward to climb out of the water. I have to hold my breath to avoid inhaling water, and if I can't hold it anymore or hold onto the rope anymore, that is when I give up.
This boat is just CRAZY weak and or has a balance issue. like if it was 3500lbs, 3100 of it is behind the center of the boat.
I am 49years old and do weigh 210lbs, but have been slalom skiing since I was 11 or 12 years old. Even when I was 18 and 165lbs and in PRIME condition, this boat pulls me up like my dad's old 1994 bayliner with the Force 120hp on it. Even back then, that bayliner 120 pulled us up worse than any boat we had. Now it pulls me up like my current boat. It's a 19.5 footer.
sangerwaker
As we age, things get more difficult. How old is your ski? Newer skis make a world of difference. I got a new slalom last year for the first time in about 30 years. I struggled to get up on my old Connelly HP. With the new one, I pop right up. Same boat...same driver. If you have a ski shop near you, see if they have a demo program. Might cost 25 bucks or so to "rent" one for a day just to see if it makes a difference for you. My new ski weighs less than 30% of the weight of my old HP. It's incredible how light they are.
Another idea is to drill some vent holes in your prop. It acts like a stall speed converter in a drag car. Some of the exhaust gasses exit the vent holes and allow the RPM's to come up before the prop bites.
It sounds like your boat would benefit from adjustable trim tabs, like Bennet makes. I had an 18' SeaRay with a 4.3LX motor (205HP), that was butt heavy. It was never a good slalom boat as the wake was a bit large, but it could pull up a slalom skier just fine. With the trim tabs all the way down, the boat had a decent hole shot. Once on plane, lift the tabs quickly.
It sounds like your boat is worse for pulling a slalom skier than my old 14 footer with a 35HP Johnny. I needed to take two breaths and hold them underwater to get up on that machine.
As for your technique. I drag my left foot, kinda like a rudder. It helps keep the ski straight. I can ski left foot forward, but I am better with my right foot forward, likely just due to practice. When starting, you want the ski parallel with the water surface, as much as possible.
Of course, you can always get up on two skis and kick one off.
stakultexsun
Well, the SAGA continues. Something STRANGE happened yesterday.
So, I'm using the 15" 15 pitch 3 blade prop which has been the best so far.
With my son and wife and I, 550lbs of people, I set "records" using vessel view holeshot timer: This is on a lake, no current, but slightly windy.
me as captain, wife in co captain seat, son in the bow. Trim 100% down.
6:18pm against the wind
0-20mph 5.7 seconds
0-30mph 8.7 seconds
Boat began feeling even sluggisher than normal about 1 hour later.
7:35pm same spot as before, but with the wind.
0-20mph 6.6 seconds
0-30mph 10.3 seconds
See below for more details.
6:20pm
Ok, then I go to slalom, Wife driving, son in the bow. It pulled me up, and seemingly slower than when it was my wife as captain and her father and stepmom on bow. I rationalized this that my son is 160lbs, and my inlaws were probably 380bs, or 360...therefore holding down the bow better.
Got up a couple of times, all good.
7:15 pm ish, same passengers, same seating, etc. IT WOULD NOT PULL ME UP. I'm guessing it got to around 8mph, and wouldn't budge. It felt like it lost 40horsepower.
I found my goggles and confirmed that the trim is/was 100% down.
What on earth could cause this sudden drop in performance?
You might repost this in the MerCruiser forum. My wild guess would be failing ign module or coil or some sort of cylinder damage.
put more weight up-front.
on my underpowered Avanti, it required everyone up front to get my lard-butt out of the water on one ski.
as for drop in power. plug in Rinda and look for codes.
stakultexsun
I am going to take it back to the dealer, but they're in Houston, I'm in dallas
stakultexsun
Supposedly, but bayliner keeps telling me I need to talk to the dealer that sold it to me.
Otherwise, I'll have to spend a few hundred $$ for debug/diagnose or what have you, and they may say it's fine engine wise. Though what happened yesterday made me wonder.
Regarding the ski I have? It is an older ski, connely something or another, 67 or 68 inches. I could buy a new ski and/or a bigger ski, the one I was using before is an old kidder, both are about what I've always used in terms of size and style. I'm sure I could get a fat ski and get up easily, then sacrifice the ability to cut hard and all that.
When I slalom, I cut up as much as my body can handle it. It is no fun just going straight. Both the kidder and the connely have been great once I get up.
I guess the real test would be to find someone who owns my boat and beg or pay them to try to pull me up on my slalom, or just let me ride/drive there boat and see if mine seems different.
cyclops222
Lots of water in bottom of boat ? You do know the bilge pump is MANUAL only in the specifications ?
I think you have a MerCruiser issue. If you have a warrantee, I would think a local MerCruiser dealer would make good. Of course I try to think logically.
Status
