82 Starcraft MR 180 floor, slight refit and leaks
redneck joe
Been perusing old threads on removing foam and @scottdanforth you I think it was mentioned this about 11 years ago. Still good?
MNhunter1
I always trash the deck joiners and use doublers to secure the different sections together, just need to remain mindful of the stringer placements.
For steering, I replaced mine with a Seastar NFB 4.2
redneck joe
In the absence of feedback on the removal methods, I will start with my filet knife.
redneck joe
switched to my shakey tool whis is much faster and can slide in underneath what does not pop out. I ordered extra long blades for towards the stern so I'm moving to the bow today. Alot seems to be popping out - there is kinda like a shell where it touches the aluminum.
redneck joe
easy stuff coming out. About 90 minutes of work, including one beer. Not looking forward to the difficult stuff
redneck joe
Got the rear side panels loose and one out. Started to pull the steering cable for the other side, beer called me plus I have a pretty young lady coming for supper tonight while the wife is in Tucson and the kids are at dads for spring break. Shrimp and cod tacos, my famous nachos and pepper rice paired with a couple top shelf margaritas.
redneck joe
oh and i can find the post to reply to but thought someone told me they replaced their steering with a seastar, looked today and that is what is on there and the cable looks pretty new - can actually read the words on the cable so i think I'm good there.
redneck joe
In case you were wondering about the pretty young lady, when daughter says she wants shrimp tacos she gets shrimp tacos....
MNhunter1
If you plan on replacing your rod holders/braces, I'm happy to send you the ones I had made before deciding to go with Starboard. 3/4" ACX ply sealed with 2 part epoxy. I never got around to finishing them up with the sanding and painting, but they are all cut to fit and ready for finishing.
MikeSchinlaub
Sorry I didn't help with the foam. I haven't gotten any notifications for this thread for some reason.
These are my usual tools for taking out foam. Cut it into squares, whack the big flat bar into the cuts, and bust it out.
There's no need to grind it out with the wire wheel.
redneck joe
I'll study on the holders. Mine are rotted a couple inches up was just going chop that off if I reused. I'm thinking about making that area into storage somehow. I have rod holders on the topside and just run with that.
redneck joe
View attachment 406399View attachment 406400
Yeah I'll take you up on your offer. Even if I do storage with doors I coul make I lockable. I'll message you.
redneck joe
Has anyone ever calculated the gash, slice and bruise per hour? Bonus for swearing coefficient....
redneck joe
OK, one side have the easy stuff out. I'm assuming a cup or wheel brush will get into the corners.
redneck joe
There are no rivets under these (dug one all the way out) so going to leave them
MikeSchinlaub
I would scrape it out in pieces. Grinding it out is going to make a huge mess that will stick to you like crazy. Foam dust is really clingy and annoying.
