Primer bulb issue
Jakem
Well the last picture of the main fuel pump definitely is...and like I said...doesn't stop clicking as soon as it gets power
Parts book shows 3 identical PRESSURE operated fuel pumps.------Good luck with this motor.
Jakem
There is three vertical yes....and there's one that's on the bottom as you can see in picture
Jakem
Right there
99yam40
what does that mean?
does the electric pump keep running as long as the key is in the on position maybe?
I would not think that is what is suppose to happen,
maybe it is sucking air instead of liquid fuel.
but I know nothing about that old motor
Jakem
Yes it seems to keep running and makes a clicking sound
Jakem
And also when I push the ignition key in the motor tilts up lol. Wich I'm sure key in is choke...I haven't figured out what's wired wrong yet
Jakem
All right well....the clicking stopped from fuel pump....and now boat won't run so there we have it....any idea of what fuel pressure should be so I can replace the high pressure pump
Jakem
To further that I can faintly hear pump and also air from the carbs
cyclops222
Get a accurate cheap voltage meter. I think your battery is running way down in power. Check the voltage with the ignition key in the RUN position.
Do you have enough electrical experience to do the voltage check ? If not ? you can damage things. Including yourself.
With both the main and the kicker motor doing the same thing ? If you have electrical fuel pumps ? Battery voltage can affect both motor. Get a marine mechanic who does Yamaha motors. Good luck.
???-----The motor should start and run with fuel pumped into the carburetors with primer bulb.-----Buying a new ( $$$ ) electric fuel pump might not be a wise step.
Jakem
I figured it out and all it was was air in the system . Once the fuel pump got primed and it was back to normal.i need a wiring diagram that makes sense to a normal person lol for this engine
