1983 25 HP Johnson hand wind starter scraping flywheel.
Armed_icebear44
Hello all,
I have a 1983 25HP Johnson, I believe the hand rewind starter is grinding on the flywheel. It has fresh worn marks and makes a kinda high pitch scraping noise. The thing is it only makes this noise while in high rpm while plained down. I've gone over the lower unit with a fine tooth comb and found no issues that would make that sound. I pulled the hand rewind starter and noticed some worn down markes on the flywheel as well as a small amount of metal shavings. This engine has been a great engine and has ran great for a long time. Any insight, pointers, fixes, general tips are greatly appreciated. Thank you in advance hope everyone has a wonderful day! And happy Veterans day weekend to my fellow Vets!
I would say 0.010 / 0.015 " thick.----But have a good look at the recoil sheeve to see if it is loose.-----And see how much the flywheel will lift up.----Perhaps a bad bearing on the bottom of the crankshaft??
Armed_icebear44
Thanks, checked the flywheel no up or down movement. Put some small washers on and will test it out tomorrow morning. Thanks for the recommendation.
