1978 Johnson 150 hp tach wire
NozonePike
I'm looking to hook up a tach on my 1978 Johnson 150 hp. I keep reading about a grey wire. This is a V6 motor and has two control boxes. Any help is appreciated.
There are 2 powerpacks on the motor.-----Look into the control box at the helm.-----Might find a gray wire there.-----The factory tachometer operates with alternator pulses.
That control box may have a feature where you plug in a tachometer.---Post picture of area below the key switch.
Well ---I can see the " picture " but I can't see whether it has an unmolested plug in for the tachometer.-----If you post a clear picture of below the ignition switch, I could tell you if it has that feature.-----Your boat is too far away for me to examine it.
saltchuckmatt
There should be a round runner cap below the key switch. If you pull on it you will see another rubber fitting with 3 wires connection. That's your tach tie in.
NozonePike
saltchuckmatt
Key switch, friction screw, rubber cap over rubber 3 wire plug. Pull on round black rubber cap revealing what's underneath.
Pull off the cap with letters and 5 on it.-----Easy to get answers when you post correct information !
NozonePike
I had a spare shifter and noticed it had a harness on it at that plug. Do you know what wires go to what? Purple, grey, and black.
saltchuckmatt
That plugs in to the spot we are talking about and those go back to the motor. Should be blue, green and red
