Mercury 50HP 4S won't crank
burkemia
Hey I'm lost.
I have a side mount console, 50hp merc (2002), wont crank.
I have done the following:
1. Checked all fuses in main fuse box. (3 x 20, 1 x 25 A)
2. Disconnected lanyard kill switch
3. Tested batteries, checked cables
When I turn key on I hear a slight noise (pump running)
Tilt/trim has power at contoller
When I go to crank..... Nothing
Mike
Wiggle the throttle handle (R-N-F), while holding the key in the start position. Sometimes the neutral safety switch can stick.
burkemia
Thx Chris - already moved throttle handle in and out of neutral... could it be the switch itself? If so how can I check it?
Gee, I never saw one break.
They are located inside the MerControl. A lug on the MerControl linkage closes the switch, allowing them to connect power to the starter solenoid, when in neutral. Maybe a wire to them broke?
