demarko210
- Jan 2, 2015
- 516
Purchase yesterday 700. That plan is to gut it and build it up for crabbing and long distance hauls out to Ocean city or Cape Charles. Motor seem to be way to big for the boat its a 115 evenrude. Didnt not plan on fixing the motor. I think the max this hull should have is about 70hp.Motor appears to be a 77 model.-----If you get this boat , it will likely need some work under the floor.-----Looks simpler than many fancy boats.
Agree. I still have a roll of 1.5 CSM and a roll of 1708 left from my grady rebuild. I currently plotting out how I will attack this.its a project boat that will require a few grand to restore the hull.
Honestly do not plan on using the motor. Will probably purchase a 40-70 4 stroke.Test compression on that motor before you spend any beer tokens on it.
Thanks I will probably ask the site admin to move this thread to the hull repair section. Unfortunately I did remove the stringers. The boat was dry but I had an hole in the hull that I wanted to do from both sides. Since I had the deck up and was planning to do the rebuild I went on and pull them up.Looks like a nice boat, Good luck, can't wait to see it completed.
My first boat I used TB3 to glue the 3 layer of 1/2 in plywood, worked well. Dang thing was heavy as hell. Advice I got from this forum. I have not decided if I will sandwich it with TB3 or CSM. Likely I will use CSM as I never done it with CSM and was advised later I should have used CSM to bond the layers. Also have an unopen 15 yard roll of 1.5 CSM and about 10 yards of 1708 that was left over from the build.You want to build and bond your transom wood together before installing in place. Then can use a few different items as listed
https://forums.iboats.com/threads/w...ogether-a-transom-wood-glue-or-expoxy.664765/
Bouts time you got to it! Looking great D!Anyone know the make of this boat? 1966 something. 16ft
