maineiac5586
Master Chief Petty Officer
- Feb 14, 2009
- 824
2001 yamaha 130 v4 2 stroke. Want to install either the analog tachometer with oil and temp warning and trim position indicator all in 1 or the digital version of the multi tach. Using a 704 binnacle remote with a separate key switch. Also using a remote 11 quart oil tank. Under the hood next to the 10 pin connector are these 2 plugs. Are these for the tach and power trim display? How does the tach get signaled of overheat or low oil? Thanks
