Manuals
Kilifi
Hi can anyone explain or show a diagram description of fuel hoses vacuum hoses primer hoses etc
Evinrude be90eledr
Kilifi
kcassells
Evinrude be90eledr
Kilifi
Just googled your engine and here are just a few things of many that showed up.
A manual is a necessity.
Kilifi
Thanks is there a search function on this forum for relevant service manual images to confirm the routing of the fuel recirculating system and vents ? Out of the manifold and crank case and how they all tie into the oil and fuel pumps
Thanks
kcassells
Thanks
No not really. Forum subject matter is too broad. Most boaters buy a manual
relative to their engine is all.
Yup you are correct, and pics/manuals will make you understand better. They will provide specific diagrams to your engine.
I just finished a part of getting my engine up and running. Lots of good guys here to help. Mostly you need to do a lot of your own research and the forum/support adds to understanding your engine and repairs.
kcassells
2 lines come of fuel solenoid that prime carbs
1 line comes off fuel solenoid that feeds carbs
1 line comes off fuel pump that feeds carbs
Each carb has a recirculation line that feeds unfired fuel in a loop from top to bottom sump.
You can get factory service manuals here:
