- Jul 18, 2011
- 19,643
Reminds me of recent beer commercials where the bed of the truck at a tailgating party is turned into a giant cooler - ice & beer.As long as you do not have a cooler full of beer along
Probably over the GVWR
No problem, @tpenfield is already breathing in, the admin at his home is very aware of insurance.I didn't mention that only because I didn't want to put that in the air.
I would love to visit there. I dropped some people off in Nantucket in August, and have always loved the area. If I only had to tow the boat, I would have an F150 with a 3.5 Eco Boost. My horse trailer that is specially built for my Clydesdale gets up to 12K plus.@Leardriver No doubt that the new trucks have awesome towing capabilities as you attest to. The fact that since 2015 most/all towing vehicles are spec'ed according to the SAE J2807 guidelines would indicate a measure of truth to the numbers. I also think there is significance in when the transition to the SAE guidelines occurred, the ratings did not go down. So, the ratings prior to 2015 were pretty solid to begin with.
My 2012 F-150 EcoBoost would easily tow the 256 SSI rig at that weight. (The F-150's of that year were rated up to 11,300 lbs.) So, not surprising the the F-350 would not even need to down-shift.
I know the 2021 (and up) F-150's are rated up to 14,000 lbs. (there are only a few configurations of the F-150 that meet that number BTW). Many of the other config's are in the 13K lb range (still excellent). I'm not sure if there is a ton of difference in the 2012 F-150 EB vs. the 2021 F-150 EB's, perhaps a little beefier all around. My limited experience towing 14K lbs on the back roads with the F-150 is having me thinking it is a little out-matched for that weight. Stopping is more the issue, but EoH brakes can certainly help.
If money were no object, I could/would get a brandy new truck, and would probably get the F-250 PowerStroke . . . For me it is a matter of 'could' vs. 'should'. If you are ever in the Cape Cod area and want to 'test' your new F-350 with 14K lbs, I'm all in
It seems like towing big loads (Boats, RV, etc.) is becoming more of a thing than it was in the past.
Lol. Very true.No problem, @tpenfield is already breathing in, the admin at his home is very aware of insurance.
I saw a very similar event once out of Atlanta heading south on 75. The truck probably had the towing capacity but the trailer took over and slung the PU around like a rag doll.@tpenfield , back about 2003/4 The office I worked at was on a curve on US 41 in De Pere Wisconsin with a good view of 2 miles of highway in both directions.
Watching traffic one lunch hour, there was a family with all their belongings loaded into a 36' travel trailer. They loaded most in the back, tongue weight must have been negative numbers. They can off the down ramp, made it about .2 miles before the trailer started to whip so badly the trailer spun the tow vehicle around. Both barrel rolled backwards thru the ditch, over the barrier fence and onto the frontage road.
They did not get hurt, but they also did not have insurance.
They were most likely 30% over the tow limit, and without proper tongue weight, doomed.
