Mercruiser 470 voltage regulator smoking
rrick
I recently bought an old boat with a 470. The first sea trial was great. No issues at all. The next day, I took it out, and after about 10 minutes, there was electrical smoke bellowing from under the engine cover. I turned off the engine and main battery switch, and it stopped. When I turned the battery back on, I could see that the sorce of the smoke was a terminal on the liquid cooled voltage regulator. (Yellow and orange wire) Does anyone know what can cause this? Is it fixable? Can anyone recommend a good alternator conversion kit available in Canada?
kenny nunez
Sierra Marine # 18-5953-1. This kit replaces the charging system with a 1 wire Delco alternator. Comes with all needed hardware. Easy to install no special tools needed.
If the starter on your engine has a solenoid mounted on the starter you will also need Sierra # 18-8220 fuse kit.
If the starter has no solenoid then the fuse is not needed.
You do not even want to repair that charging system, the parts are expensive.
Dubed
Call Kevin @ Breezeworks in Florida. He has nice kits available for a reasonable price
nola mike
Whoa, $750! That's crazy for a $100 alt and a bracket. I think I paid less than ½ from breezeworks .
I have access to a laser, a lathe, and a pile of alternators.
I wouldn't pay more than $300-$350
Bt Doctur
If you go with Breezeworks, remember to center the pully on the balancer.
The link i posted uses the oem balancer and pully groove
ROY WILLIAMS
my MCM470 year 1978 . the voltage regulator is worn out is done ... the stator of the front engine is the stator coils . the 2 wires yellow/red the stator coils take it off the wires ... the red wire take it off voltage regulator , and the alternator updated it off the alternator output voltage red wire . the excitation of the alternator ignition terminal , wire engine key .
over 20yrs ago ... the voltage regulator stator done ...alternator LESTER 12174 great ..
my boat is now today 2023 ...very good .
Dubed
The kit I bought from Breezeworks also uses the OEM balancer. They also have a high mount and a low mount kit. I think it was around $345., but dont remember
