Bad engine coupler or spun prop hub?
Nede2
The known good prop I have available is a stainless 4 blade 14.125”x20 pitch. It currently has black max aluminum 3 blade 21 pitch 14.25”. If the stainless prop works would there be any problem keeping it on if it doesn’t trip the rev limiter and stays in WOT range? I didn’t know that you’re supposed to go down 2 pitch when going from 3 to 4 blade.
nola mike
That should be fine
