1990 15 hp Johnson won’t start, sort of sounds like it’s sucking air/leaking air
jitterbug127
Another angle, these are from earlier today. I guess it would be broke. Looked ok to me but the only one I had that was obviously broken fell out when I took the flywheel off.
David wright
When you fit your new woodruff/flywheel key make sure you use a little bit of grease on the dome side to help with friction whist fitting the flywheel back on or its an absolute nightmare to fit
jitterbug127
How does this spark look to you guys?
  • IMG_4479.MOV
  • IMG_4480.MOV
David wright
Spark is great just timing is off badly its that sheared key don't worry about anything until you have replaced that broken key
jitterbug127
More pictures
jitterbug127
You know I’m glad I posted this. I would’ve never thought that key was sheared. My novice eyes it looks just fine
David wright
Well hopefully the new key will help you the crank looks a little bit bent does it spin ok ?
Key looks fine to me.----And use no grease when fitting the flywheel.----Must be clean and dry.
jitterbug127
Couple more pictures of key.
jitterbug127
Key
David wright
I do too. It doesn’t appear to be broken to me. If it is I’ll swap it at a later time. I don’t know what to do to fix my motor from here.
Pitting at the top of the crank and is this top part of this a part of the key look at the picture of your flywheel you have a misshapen sharp point
