Mercruiser 6.2 repower/finding an engine
miketoppi
Hey guys I have a 2002 6.2 377 mercruiser I’m looking to find a replacement engine. I’m wondering has anyone been able to repower with mercruiser 6.2 383? They are cheaper since the 6.2 377 is getting harder to find. I think the computer would either have to be flashed or swapped and I’m not sure about anything else that wouldn’t fit any help would be appreciated, thankyou!
Scott06
I believe the 383 is just a remanufactured 377, given a .030” overbore. I cant see needing to reflash the ecu for this. Try michigan motorz i belive they sell reman and new base engines
stresspoint
compression ratio may be a little different but i think the ECU will manage just fine.
alldodge
Boring this motor is do different then boring any other motor (4.3, 350, 454, 502,etc) clear up to .060
Merc programs the ECM fat, so as it's bored there is still plenty of fuel
Scott06
reman 6.2 https://www.michiganmotorz.com/6-2l-vortec-marine-engine-1996-current
New 6.2 merc longblock
New base engine from different supplier pricing is better
Reman https://marineengines4less.com/remanufactured-6-2l-383-stroker-vortec-1997-up-marine-base-engine
miketoppi
Man thanks guy that’s some good information and thankyou for the links aswell!
what is wrong with the original engine?
your local engine machine shop can also help you.
the merc 6.2 is nothing but a 350 block, a GMPP crank and GMPP rods
miketoppi
At this point I don’t think I want to mess with any old parts, the old motor sucked in water most likely a mixture of old parts and failed gaskets. I’d rather turn the key and not have any problems. So I’m looking to just get a full package all accessories included or atleast new from oil pan to valve cover and then I can piece all the other new parts together.
if you are looking for a new long block, you can go with either your local engine builder, you can order new GM motors yourself, or you can get one thru places like michigan motorz, marine power, etc.
to that you buy new exhaust manifolds, etc and migrate the other parts
if you want a new complete motor, then see your Mercruiser dealer. if you have a good relationship, you are looking at $12k for a remanufactured motor with new accessories, or a lot more money for a brand new motor. (the new 6.2 with DTS is about $40k from mercruiser)
if you boat in salt water, suggest a heat exchanged cooled motor.
