VP 4.3GS Carb Tuning Vacuum Port?
This are not externally adjustable
You can remove the bowls without pulling the carb if you need.
Lou C
Are you sure that the needle valves are holding & cutting off fuel flow when they should?
dubs283
What setting are the idle/air screws set to?
Spec is around 3/4 turn out from seated then adjust accordingly. I've never had a properly tuned holley on a sound engine at more than one turn out from seated
If the float is too high, fuel gets pushed thru the boosters
As Lou asked, are the floats cutting off flow?
valleyviewlawns
Screws are out 3/4 turn.
valleyviewlawns
When I put the new needles and seats in it, I flipped the bowls over and set them so they're level with the top of the bowl. Not resting on the bowl, level with it.
Lou C
An easy way to tell is to remove the carb drain the fuel out & see if you can blow thru the inlet with the carb flipped upside down. If you can the needles aren’t holding.
valleyviewlawns
Set like this. Both primary and secondary.
Lou C
No particular pressure you just shouldn’t be able to blow thru it
dubs283
Can you see fuel dribbling down the venturi clusters at idle/near idle speed?
Is the ignition timing and firing order correct?
Is the engine itself mechanically sound?
What brand/style rebuild kit did you install?
valleyviewlawns
I do not see fuel dribbling down the Venturi clusters at idle. The ignition timing and the firing order is confirmed and correct. I will do a compression test this evening. I used the Holley trick kit that Holley technical support sent me.
Lou C
Wanna laugh I had the EXACT SAME PROBLEM with a brand new 4160 specified for the V6. Rich running no matter what I did. Called their tech line tried everything. In disgust I pulled the 30 year old QJet out of the garage that I thought was too old to rebuild. Took my time to really clean it & checked all the passages. Bolted it on and, like magic ran perfect. About 6 months later got curious & took that infernal Holley all apart. What I found was that the clutch bolts on the secondary metering plate were loose. This may have allowed more fuel flow from the secondary system causing the fuel mix to be too rich. The Holley is designed to flow some fuel from the secondary system to keep the fuel in the rear bowl from going bad. Anyway I left the QJet on it since then & still running fine. The Holley still sits in the box on a shelf in my garage. So check that if you haven’t!
Not sure what I’m gonna do with it but I like spare parts. Honestly while Holleys are super easy to get parts for I don’t think their quality control is all that great.
valleyviewlawns
When I had the Holley off the engine and flipped over on my workbench, I noticed that there is about 3/16" play on the secondaries between closed and sitting on the adjustment. I was trying to set the transfer slots. I set it so when they were open, there is only about .020" reveal on the transfer slot, and none when it is fully closed.
