Volvo Penta 5.0FIPNCSCE SLOW mode
JTown12345
The tachometer has a fairly direct connection to the ecm through the coil primary wiring
The temprature gauge most likely has no wiring/component association with the ecm
Just checked no difference. Pulled off the
JTown12345
Well oddly enough I’m sitting at the dock and now the OTHER engine is running rough idle and the original is smooth. I swapped the coil from one engine to another, no difference.
Temp good, oil good. I think it might just be older gas. It runs well then kind of jumps a bit. I’m running it down right now and I’ll head to the marina to fuel up with some 93
alldodge
Don't put 93 in it, stick with 87
Running higher octane for a motor that only requires reduces power and performance
JTown12345
Didn’t know that! They only seem to have 89 but I’ll go lower octane then. Again, Ty for your guidance as it’s greatly appreciated
alldodge
89 is better then 93, just that 87 is best but 89 is ok if that's all you can get
JTown12345
This explains everything
PM me, I have all the info you need
So I pretty much ran the engine there at the dock. I think the fuel is so bad in it it just eventually stopped sputtering and running when I got down to a quarter tank. Debating whether or not to drain it first or get some fresh stuff in there.
When I changed filter the other day it smelled okay, looked clear. IDK if it was bc of the oooold fuel and sea foam or other additives they used to winterize.
JTown12345
Oh I forgot I put STARBRITE in the engine prob when I didnt have to and it clogs filters. Gonna replace it tomorrow and hope my engine doesnt explore
dubs283
My post #29 about a PM was meant tongue in cheek as reference to your post #24 which is so vague it makes very little sense
Sorry for the confusion
