Inherited new boat. Unsure what it is exactly
The only information I have is it's a 1965 vhull. Not really sure about anything else. Any information would be appreciated. I'm looking to build some decks and a compartment in the back to hold the battery and gas tank(have a curious 3 and 5 yr old that might mess with it). Thanks for looking!
-Robbie
jbcurt00
Length?
Looks like factory bow rider, Super Sport, but I don't think a bow rider SS was available in 1965
roscoe
Does it have a coast guard capacity plate?
Oh yeah, its been modified a bit.
You definitely NEED a new steering cable. That one is a disaster waiting to happen. Thats a lot of HP to be flopping around back there with no steering.
Also, those 4 screen door pull handles for tie down anchor points are not right.
Anchor points need to be through bolted in the transom. Not screwed into the sheet metal.
Splash well looks late 60's.
Windshield looks newer, 80's ?.
I wonder if they just did a really good job of converting a Jupiter? to an open bow model ?
Looks like they did a nice job, but I would be getting that steering cable replaced ASAP.
DLNorth
Agreed, it's either well modified or newer then '65.
Post the S/N and I'll take a guess at the year.
Hint - the 60's have a number that usually starts with the year (2 digits) - ie; 67 xxxxx.
Moserkr
Chief Officer + Starmada Splash Of The Year 2021
Whatever kind of Starcraft she is, thats a nice boat! Welcome and enjoy working on it, great canvas to start with. Beyond what has already been said, Id be looking out for ferrous metal that the PO put in. Would also look close at that transom, check it for rot.
Thank you for the replies. I'll get pics of the numbers. Not sure why the screen door pulls were used but I'll replace that. I see a lot of boats around town don't even tie down the middle like that.
I really want to find or build a door for the back compartment that contains the battery and gas tank. Anyone have any ideas or know where I can pick up prefabbed ones?
I was thinking two sliding doors or one long plywood sheet/door with hinges at the top.
The picture I provided is not my boat but the area. I believe that's what the original doors looked it. Mine is open
Thanks!
tkdrumr
Thanks!
Congrats on the "new" boat. I have two SS 160's ... a 1974 that used to have those double doors and an 84 that has a plywood door (see the pic) on a piano hinge that flips up. I removed the double doors from the 74 because it was a pain to get in there with the gas tanks, batteries, bilge pump, etc. It's open right now but I might put a vinyl snap on cover like some boats have or the flip up plywood. I'm going to put a casting deck on the 84 in front of the opening.
That's cool. Is that pressure treated? What's the vinyl snap on cover? I was thinking maybe a tarp with buttons. Idk. I just don't want the girls in there
Here's the front end. I was thinking about putting a deck upon those existing steps maybe braces in the middle.
airshot
Even if they never come in contact with the aluminum?
While that might slow down the reaction, those chemicals will leach out every time the wood gets wet and sooner or later will get to the aluminum. There are folks that have gotten away with using treated lumber with no issues....how much of a gambler are you ??
Sharpie223
My thought is that weathering will affect the wood more than microbial rot. The chemicals won't protect against the weather.
tkdrumr
Sorry, was offline getting ready for a camping trip. It's just painted plywood. The snap cover I've seen is just a piece of vinyl with snaps. Should keep the girls out.
