Evinrude 4 HP deluxe
saltchuckmatt
Hi, I have a 1989 four horsepower deluxe. It has the locking and unlocking mechanism for the tilt but it doesn't seem to have a tilt lock when it's in the fully upright position. I went to the parts break down and I couldn't see any locking levers. Did this motor not come with one?
Matt
saltchuckmatt
Might be missing.....funny it being on the other side, I'll check for it.
Thanks CrosbyMan
oldboat1
Not sure if this misses your point, but you need the tilt pin (#23) to lock the motor in an upright running position. Note also the shallow water bracket and lever (#65) that prevents the motor from locking in the upright position until released with the lever.
saltchuckmatt
Not sure I know what your talking about but it looks like I'm missing part 54 through 56
Vic.S
The Deluxe version does not have these parts.
The diagram in Crosbyman's post of the standard 4hp model not the Deluxe version. They are very different.
I thought maybe it would have the same tilt support lever as the 6hp model but it does not have that either. There does not seem to be any method of supporting the engine in the fully tilted position. I have some recollection of this being asked about in the past As far as I can remember the solution is to tighten the nut (#12) on the tilt bolt (#25) until the friction on the conical washer(#21) will just hold the motor in the fully tilted position.
F_R
So I take it the shallow water drive isn't enough tilt for trailering? There always is the old-time tilt / trailering method. Tilt it up and stick a piece of broom handle under it. ;)
Crosbyman
bummer :-(... only one model does not have it on the parts place . I had to pick the deluxe model which comes without the extra part ...????
1989 Evinrude 4 hp E4RDHCEC all others versions have it​
saltchuckmatt
You'd think if it was called a "deluxe" it would have one.
saltchuckmatt
We beach our boats so they have to come way up....
Vic.S
You could investigate the possibility of fitting the tilt lock components from the 6hp model
#93, #94, #95, #96 (2 off), #97(2off) Although the port side parts are probably unnecessary
