Dean's List gets another motor
Was going to ask if you got the motor installed
alldodge
Not yet, motor is ready once old one is removed. Just brought it to my lot so we can Start the work of pulling old
alldodge
Got the prop off but not able to get the shaft to separate from the transmission collar. Ordered another puller, hope that gets it done
alldodge
Managed to get the prop shaft to break loose from the coupler. Lots of pressure was used and there was a loud bang when it released. Worked off and on for a few days and got no where. Bought the right puller and some 6.5 inch grade 8 bolts and it came loose. Motor comes out tomorrow if all goes well
Edit: they were 7 inch bolts and we cut 1/2 inch off, chased the threads with a 7/16-20 die and then used it
alldodge
Motor came out today
This is new, a tray under the intake. Have not seen that before, guess we will install in rebuilt motor. Injectors go out tomorrow to Smitty's in Michigan
Gen V and VI have the oil control baffle. Keeps intake cool
alldodge
Should be Gen 6, boat is 1999 but bought in 1998. Who knows might be older. Maybe have a look at the plate in it
alldodge
Original motor is stripped and put back in the crate. Started putting things back on rebuild and 2 issues came up.
Oil port below the distributor had a plug installed by the machine shop, WHY we have no idea. Would not be a major problem but the dog turd guy also used some kind of loctite and it won't come out. I used acetylene only and Ox/Axe and no matter what heat was not able to break it free. So we're moving the ECM switch down by the oil sender
Installing the damper on the crank and it's not going easy at all. This is old damper and brank new eagle crank. Removing the damper I had to use the pulled almost the full length just to get it off. A local shop has a pusher so going to try and borrow it
Probably used an electric burp gun to install the plug
Scott06
Maybe clean up inside of damper with a flap wheel to remove burrs and clearance it a little
alldodge
Brand new never been used crank, don't know what a flap wherl should be able to do
Scott06
Seemed like from your comments that balancer was more difficult than it should have been to remove. use a flap wheel and die grinder to clean up ID of balancer and open it up hair so it goes on easier. Possible its been on and off before someone may have beat it up…
use them all the time at work on machine repairs and overhauls when things have some wear or damage.
ScottinAZ
Master Chief Petty Officer
yep, check it for burrs, clean any crap out of it, but DONT GO NUTS and make it too loose..... these and the scotchbrite discs for a die grinder have fubarred more machined fits in the hands of an amateur than anything else......
alldodge
Most everything is back on the motor, including injectors and rail (not shown). Waiting on a thermostat for couple weeks. If we don't get it soon we're going to use the old one.
alldodge
Sometimes you just can't catch a brake.
Good and Bad news
Good
Jump pins 5 to 6, ECM powers up and fuel pump runs.
Bleed fuel rail and getting a steady 40 sum psi. Pump shuts off and pressure holds most of it.
Crank motor over without powering up to find TDC number 1
Install Dizzy, finish connecting
Bad
Motor cranks but no spark
Motor ran fine for many years and now no spark. Check fuses, grounds, power to Dizzy and coil. Remove module and test Dizzy coil and all good. Are going to get a new module
