tilt wires getting hot during lift?
1975oday22
this was done before i got the boat. not my wiring. i goto raise the stern drive up and now it wont go full up. battery was charged last night. brand new battery this year. anyways the wires are getting hot to the touch with just a few pulses of switch up. any ideas?
dubs283
Heat means excess resistance caused by too small a diameter wire, wire length, poor connection, issue with the component accepting the load, etc...
The connections pictured look questionable, have you peeked under the tape?
airshot
You need a readung on the battery from a digital meter. 12.6 volts and up is a full charge...12.3 volts..battery is low....below 12 volts battery is considered dead..
1975oday22
not yet. when i noticed this i emediatly took a pic and choose to post before taking a peak. too me the wiring is shoddy looking. (ya i know my fuse block the same but i actually wired it correct myself. just doesnt look pretty. but it works)( and no heat) lol. so on this note. i will now go disconnect the neg post and open up the tape .
1975oday22
i know all that airshot. but thanks for telling me this again. but just to satisfy your curiosity i will take a measurement of my battery . cheers
1975oday22
voltage, battery, wires. the other end is a 2 wire connecter looks like deans plugs
1975oday22
ok in a nutshell. video explains. however. i was a bit sarcastic. lol
  • IMG_2122.MOV
froggy1150
Ensign
If that is a stringer drive the green is positive power down. The blue is positive power up. Tilt motor don't have a ground. It uses the case bolts to intermediate housing for ground. Those connections are crap also and need to be changed
1975oday22
any suggestions? or should i scrap the center connection and wire the motor blue green to the top blue green, solder then heat shrink?
1975oday22
nope not deans, just 2 spade connectors into a plug. eeeeesh. thats how i got this boat. going to go through all engine wiring and make sure the rest is fine.
dubs283
Those spade connectors are not recommended for the heavy load of the tilt mechanism.
If this is indeed a "stringer" the tilt and trim are two different systems. Tilt moves the drive very swiftly up/down. Trim changes the angle of the entire package (engine, transom assy/housing, drive) to achieve best on step performance. Hence the large rubber gasket at the transom
1975oday22
yes i know. i had to replace the trim motor already as there was none with it. as for tilt i know wich one that is. question here was should i take the wires from the tilt motor and solder onto main wires where i pointed out then heat shrink? yes or no.? other suggestions?
dubs283
Didn't watch your video, .mov downloads and often doesn't work anyway
My suggestion would be to abate the spade terminals and either butt solder or heat shrink butt connect the wires in question. Get yourself a decent shop manual with proper wiring diagrams/service info and wire the system as it was oem
1975oday22
i have my manual, its pdf and i have been over all the wiring diagrams. i noticed this because of no lift again. touched the wires and they were hot. i will be joining them together and soldering with heat shrink. thanks
1975oday22
just in case the mov. does not work.
  • [freemake.com LOGO] IMG_2117.mp4
froggy1150
Ensign
Get the same size or slightly bigger (and color) wire. Replace from the eyelets to the tilt motor connector. The butt connector with integrated heatshrink work well. Every splice point is also a possible failure point. Connectors should be tight. Crimps should not pull apart with a firm tug. If you have heat... something is not right
nola mike
Do we know what you're working on yet? Could also do a voltage drop test across various points in your wiring to see where the increased resistance is.
1975oday22
well as it stands, when i toggle up (lift the outdrive up) the voltage drops considerably. i will be fixing the wires today. as for anything else. as i said , i will go through the whole lot of wires on the engine. . i will also be cleaning the contacts on each solenoid. gonna be a fun time for me. lol. cheers
1975oday22
as it stand right now. i have to buy butt connectors that will fit the wires. i have smaller ones but not any med to large size. as for the black spade connected wire. as i figured it is connected to the tilt motor top bolt. to the engine block. why? i do not know. will report back when i have everything on hand. cheers and thank you again for the help and advice.
1975oday22
found out the reason why my wires were getting hot on lift. however i have cut the wires to be ready to install the butt connectors. the sterndrive was to the left. it should be straight when tilting up. lol...... (headsmack)
