Capri 175 with mercruiser 3.0 alpha won’t start
ClaySmoove
Capri 175 with mercruiser 3.0 alpha won’t start. It’s chugging but it just won’t turn over. What might the reason be and where should I start looking for issues? Brand new boat owner here so pls be nice lol
Which ignition system? If you have points, start by servicing them
nola mike
What do you mean by points?
Don't worry, doesn't look like you have them. Have you started the boat before? First step is seeing whether you have spark and fuel. Pull the spark arrestor. See if the choke plate is closed. When you pump the throttle you should see gas squirted down the throat of the carb. You can also pour a bit of gas down the throat of the carb. If fuel related the motor should then at least cough when you try to start it. Can also check for spark with a spark tester.
