Boating Trim - electrical problem
gkline
Hello,
I have a 23-year-old Bryant, in great shape. On the water this season, I noticed that my hour meter did not illuminate, and my horn did not work. Currently, it is in my garage and dry, and these components work fine. Then, in my garage, I noticed that the trim on the throttle stick started acting funny. It will trim down, but not up. Yet the trailer trim button works fine. Also, the trim controls on the stern work fine. It is only the up button on the throttle. My battery is fully charged.
Any ideas?
Could there be an issue with my boat being less grounded when on the trailer vs in the water, making these electrical issues?
Thanks,
Greg
alldodge
What motor do you have?
If it's a Mercruiser then most likely the trim limit switch on the port side of the gimbal ring
gkline
So I need to clean out that trim switch, probably a connection problem there
alldodge
The limit switch probably needs replaced or just bypass it. If it's bypassed then the trim button will bring it full up same as trailer button.
Not at my computer or I would post a wiring Pic. There is a purple/white and blue/white wires that go to limit switch. If these are connected together the switch is bypassed
airshot
Start checking electrical connections for corrosion. Doesn't take much corrosion to cause an issue.
Connections to the battery or elsewhere?
Ayuh,..... Welcome Aboard,...... I'd start there, both ends of both cables, 'n move down circuit from there,....
Shiny metal Clean,....
