Polishing or paint
harringtondav
When i wet sanded I went up as far as 3000 grit.
Yes. Get a dual action/random orbit 6" sander. Use wet discs. You can find fine grit discs. For your boat I'd start at 1500 grit and work your way up about 300 grit/pass to around 2500. Finish hand sand with Meguiars Unigrit 3000 wet.
Then put a foam polishing head on the sander and finish with a high quality polishing compound. ....I like 3M Perfect-It Machine Polish 06064, and then wax.
Then every spring hit it again with the polish and wax. The gel coat will look new until you sell or scrap the boat.
eggs712
I just did a section of my gelcoat up to 1500 wet before switching to compound. It looks like a mirror with no swirls using a random orbital sander and a rotary polisher. Using a foam interface pad on the sander helped too.
edgepa
I was told that I couldn’t bring back the color on this boat and I should paint it. Glad I didn’t listen. Wet sand 80/1500/2000. Three levels of rubbing compounds/ polish. Finished with wax.
Correction to my post… my first pass was 800 grit. Not 80!
harringtondav
But everybody seems to have a different tolerance level for cosmetics.
Apparently. I see several here are good at 1500 grit and go for the compounds. You get as much out of the process as you put into it.
I always gave my boat an annual gel coat a spruce up. By looking down the finish at a very shallow angle I could see the difference between just polishing compound, or a pass with the Unigrit 3000 before the compound.
You have to sneak up on a true glass finish. Polishing compound knocks the tops off the sanding scratches. Coarser grit leaves grooves that can't be polished out.
