correct prop for 74 mercruiser 140hp
QBhoy
In the early 70s the 140 MerCruiser had a WOT range of 3900 - 4300 rpm
Excellent info there. Couldn’t remember what it was. So looks like he isn’t too badly set up at all then !
Chevyls6
yes very good to know. I thought 4400rpm was too low but i stand corrected.
jimmbo
I wouldn't say 'corrected', informed is more appropriate. However, it is important to have the information of any engine you own. I really don't understand how New Boat Owners lose the Operator Manuals the boat/engine comes with. Engines should have something Permanently attached to them that states all the Specs.
I don't know what changes were made to the 181 in.(3 liter) engine since the 70s, maybe nothing, maybe several things affecting it's powerband and/or it's ability to reliably rev higher. Since the 70s, almost all the Inboard Engine rpm ranges have been raised about 1000 rpm, some in two steps, others in one
Chevyls6
I know for sure they went to a different cylinder head casting with smaller square ports in the early 90s and a 1 piece rear main seal. The parts catalogs also mention a dished and flat top piston depending on application.
QBhoy
You’re right there, for sure. About the rpms raising on these engine over the years. Slightly related to that…I’ve always wondered around the 350 mpi at 300hp and 4600-5000 rpm and the the 6.2 mpi at 320hp and 4800-6200 rpm. You’d think a stroked engine and 200 more rpm might do a little better than 20hp extra ? More confusing to me…is that I think there may be a 350 mpi variant that can range up to 5100/5200 and still remain 300hp. That’s weird. It’s one of the obscure models of it. Can’t remember which though.
