2006 Volvo penta 3.0 180 horizon bogging down
Ok.. so I started have a little issue with bogging down when doing a hole shot or wide open throttle. It’s a ski boat so in order to get people up on the skis I have to punch it. Now whenever I go full throttle or even 3/4 it Boggs down until it dies. If I slowly start the throttle it will go full throttle no problem. I was originally told it was probably a carb issue. I rebuilt the carb and still the same issue. I have so far replaced the entire carb with a new one. Replaced plugs , wires, distributor and cap. Cleaned the fuel filter I plan on replacing when new one comes. Oil and filter.
And still having the same issue starts up just fine but Boggs down as soon as I do a hole shot. Never had issues before where it would completely die but now it’s guaranteed to die when I do so. Any help would be very appreciated!
alldodge
Do a compression test to verify health of motor
Which ignition system and has timing been checked?
Lou C
Fuel pump pressure & volume & anti siphon valve on the fuel tank…
Did a compression test everything was in good tolerance I have not checked timing and I'm not sure which ignition system it is
I forgot to mention that when I go into reverse it does the same issue but doesn't if I go very slow
If your gauge is accurate then your hp is down, but still should run fine. The lowest cylinder should not be more then 10% lower then the highest
Yea I remember they were within like 2 points of each other from the lowest to highest
